[Commercial meshers] Procedure tip to create a mesh from scratch
Old   April 30, 2018, 05:52
Default Procedure tip to create a mesh from scratch
Andrew
Astan is on a distinguished road
Hello everyone, I'm taking the first steps in the world of CFD and kindly I would need advice on how to generate mesh in OpenFoam with SnappyHexMesh.
I do not mean parameter settings.
I would like to understand what is the logic to be adopted to start the mesh procedure, we start with a mesh made at random and then thickens where it is needed? How do you understand where you need to thicken?
How do you understand if the mesh is of good quality?
In general, how do you proceed?
What is the criterion for determining the size of the BlockMesh in a problem of studying a vehicle's CFD?
Thanks in advance for the time spent reading the message and for any answers
Astan is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[mesh manipulation] polyDualMesh, create a tetrahedral mesh from a polyhedral mesh Martin80 OpenFOAM Meshing & Mesh Conversion 5 January 30, 2013 22:07
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
