[Gmsh] What is the meaning of DefaultFaces
Like Tree1Likes
  • 1 Post By T.D.
Old   January 14, 2008, 09:08
Default What is the meaning of DefaultFaces
Francesco Boschetto
francesco_b is on a distinguished road
Hi all,
I used Gmsh to create a very simple mesh, a cube, which has 3 boundary types, then I converted it using gmshToFoam and I got this warning:
--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 577
Found 1222 undefined faces in mesh; adding to default patch.
When I loaded the mesh in ParaView it was ok. Then I loaded it through FoamX and i saw in my geometry 4 patches, the 3 I defined and defaultFaces. Where is my error? please can anyone give me a hint? Can you explain me what is the meaning of these faces? Are them the internal element faces?
If you need I can send you my file, I don't know how to upload it (maybe someone could explain me how to do it?).
Thank you in advance,
Best regards
Francesco
francesco_b is offline   Reply With Quote
Old   January 14, 2008, 09:45
Default The defaultFaces are all the b
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The defaultFaces are all the boundary faces that have not otherwise been assigned to a particular patch. Assuming that they correspond to some walls that you did not explicity define, you'll likely wish to change them from 'empty' to 'wall' in constant/polyMesh/boundary
olesen is offline   Reply With Quote
Old   October 10, 2010, 16:39
T.D. is on a distinguished road
but it is not logic to change them to walls, is there any better idea to get rid of these "defaultFaces" ?
thanks
HumanistEngineer likes this.
T.D. is offline   Reply With Quote
[Gmsh] unwanted defaultFaces after exporting to foam 5.0 deepbandivadekar OpenFOAM Meshing & Mesh Conversion 8 July 3, 2018 16:37
Meaning of values in combustion kane OpenFOAM Running, Solving & CFD 1 May 14, 2018 05:13
How to get rid of the defaultFaces, Courant number diverge. liguifan OpenFOAM Running, Solving & CFD 1 April 30, 2011 23:13
[Gmsh] How to get rid of the defaultFaces liguifan OpenFOAM Meshing & Mesh Conversion 0 April 30, 2011 22:53
What's meaning of UDF FUNCTION zhaoxinyu Fluent UDF and Scheme Programming 0 March 31, 2010 08:04
