[Commercial meshers] FOAM FATAL ERROR Cannot find match for face 4
Old   April 6, 2008, 05:01
Default FOAM FATAL ERROR Cannot find match for face 4
Christian Egerer
chrisegerer is on a distinguished road
hi,
I get the following error message after running fluentMeshToFoam.
Is there anything wrong with the .msh file or how do I have to interpret the error message?
I'm quite new to OpenFOAM so I would be glad for any help!
Thanks in advance!
error message:
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
sh: gaddr2line: command not found
--> FOAM FATAL ERROR : Cannot find match for face 4.
Model: pyr model face: 3(0 1 4) Mesh faces:
5
3(52802 8982 172140)
3(8982 52802 706)
3(1789 706 52802)
4(172140 1789 706 8982)
3(172140 52802 1789)
Matched points: 5(172140 8982 172140 8982 52802)#0 Foam::error::printStack(Foam:: Ostream&) addr2line failed
#1 Foam::error::abort() addr2line failed
#2 Foam::create3DCellShape(int, Foam::List<int> const&, Foam::List<foam::face> const&, Foam::List<int> const&, Foam::List<int> const&, int) addr2line failed
#3 main addr2line failed
#4 start addr2line failed
From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
in file create3DCellShape.C at line 281.
FOAM aborting
Abort trap
chrisegerer is offline   Reply With Quote
Old   April 7, 2008, 04:58
Default Try running fluent3DMeshToFoam
Mattijs Janssens
Try running fluent3DMeshToFoam.
Old   April 7, 2008, 05:43
Default fluent3DMeshToFoam doesn't wor
Christian Egerer
fluent3DMeshToFoam doesn't work either. When running I get this error message:
--> FOAM FATAL ERROR : Do not understand characters:
From function fluentMeshToFoam::lexer
in file fluentMeshToFoam.L at line 704.
I also tried to convert it on a different OpenFOAM installation this morning. Same errors.
Old   April 7, 2008, 05:54
Default try dos2unix on the meshfile b
caw
Christian Winkler
caw is on a distinguished road
try dos2unix on the meshfile before using fluent3DMeshToFoam
regards
Christian
caw is offline   Reply With Quote
Old   April 7, 2008, 06:40
Default dos2unix didn't resolve the pr
Christian Egerer
dos2unix didn't resolve the problem. After "FINISHED LEXING" there's an FOAM Warning. program aborts saying "segmentation fault".
Old   April 7, 2008, 08:15
Default Hi Christian, Do you have the
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Christian,
Do you have the possibility to run the same command but under valgrind?
Dragos
dmoroian is offline   Reply With Quote
Old   April 7, 2008, 09:04
Default Hi Dragos, while running valg
Christian Egerer
Hi Dragos,
while running valgrind, there was the following output:
==14024== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 4 from 2)
==14024== malloc/free: in use at exit: 85,479,992 bytes in 1,915,608 blocks.
==14024== malloc/free: 11,416,411 allocs, 9,500,803 frees, 879,490,377 bytes allocated.
==14024== For counts of detected errors, rerun with: -v
==14024== searching for pointers to 1,915,608 not-freed blocks.
==14024== checked 64,396,024 bytes.
==14024==
==14024== LEAK SUMMARY:
==14024== definitely lost: 0 bytes in 0 blocks.
==14024== possibly lost: 38,955,197 bytes in 3,505 blocks.
==14024== still reachable: 46,524,795 bytes in 1,912,103 blocks.
==14024== suppressed: 0 bytes in 0 blocks.
==14024== Rerun with --leak-check=full to see details of leaked memory.
Does this make any sense to you?
Thanks for your help.
Christian
Old   April 7, 2008, 10:07
Default So you don't get any more segf
dmoroian's Avatar
Dragos
So you don't get any more segfaults?
Are you running on 32bit or 64bit?
Dragos
Old   April 7, 2008, 10:15
Default no, I don't get any more segfa
Christian Egerer
no, I don't get any more segfaults.
running on 64bit.
At the moment I think that the problem could base on the export-process from ICEM, because I tried with some other .msh files and there were no errors.
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 12:48
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
