June 26, 2011, 23:42 |
How do I view results?
Rep Power: 15 |
Greetings,
I'm new to using snappyHexMesh - once the utility is run how do I view the resulting mesh? I've had a bit of a look through the forums and it seems paraView may have problems as the cells arn't hexs. The commands I entered were: blockMesh decomposePar foamJob -p -s snappyHexMesh reconstructParMesh -mergeTol 1e-06 -time 1 reconstructParMesh -mergeTol 1e-06 -time 2 reconstructParMesh -mergeTol 1e-06 -time 3 paraFoam But this just shows me the initial Mesh. Thanks |
June 27, 2011, 01:45 |
Partial Success
Rep Power: 15 |
I had partial success with the command (run form the case directory);
[IMG]file:///tmp/moz-screenshot.jpg[/IMG] p { margin-bottom: 0.08in; } foamToVTK Then from paraViewer opening the resulting files in the VTK folder manually. However it still doesn't seem to be showing the internal mesh of the resulting bounding region, just the mesh of the surface of the .stl object. Still this is some progress. Baby steps and all that... |
viewing snappyhexmesh |
Display Modes | |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 21:49 |
View Conduction, Convection, Radiation Heat Transfer (Watt) in results | EGY | CFX | 0 | March 28, 2016 12:18 |
Using results from experiment | studygroups2000 | FLUENT | 0 | November 25, 2015 18:29 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 22:36 |
View Sampling Results | Smed | OpenFOAM Post-Processing | 1 | January 4, 2012 05:21 |
