[Commercial meshers] FluentMeshToFoam hangs with no error
Old   November 26, 2006, 15:22
Default FluentMeshToFoam hangs with no error
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
I generated a hex grid for a free-surface-piercing NACA 0024 using Gridgen from Pointwise, Inc. It is a simple c-type grid with clustering near the wall (for wall fxn) and near the waterplane. However, when I try to convert it, it simply hangs and does not report an error. Any suggestions on how to debug this?
Here is the output:
Exec : fluentMeshToFoam . SPNACA SPNACA/spnaca24_sublayer.cas
Date : Nov 26 2006
Time : 15:19:30
Host : ritchie.aset.psu.edu
PID : 4877
Root : /scratch/egp11
Case : SPNACA
Nprocs : 1
Create time
Reading header: "exported from Gridgen 15.09R3"
Dimension of grid: 3
Number of points: 345321
number of faces: 1005100
Number of cells: 330000
Reading points
Reading uniform cells
Reading zone data
Embedded blocks in comment or unknown
Found end of section in unknown
,Reading uniform faces
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
----------this is where it hangs---------------
thanks,
Eric Paterson
egp is offline   Reply With Quote
Old   November 26, 2006, 15:40
Default By the way, my Fluent case fil
egp
egp's Avatar
Eric Paterson
By the way, my Fluent case file was written as ASCII, and I deleted the DOS control characters using dos2unix (unfortunately, my desktop machine is a Dell).
Old   November 26, 2006, 16:08
Default This is a strange place for th
Hrvoje Jasak
This is a strange place for the converter to hang: you have successfully finished lexing. Can I have a look at this file if it's not confidential?
Hrv
Hrvoje Jasak
Old   November 26, 2006, 17:07
Default Hrv, You can download the f
egp
egp's Avatar
Eric Paterson
Hrv,
You can download the file from:
http://idisk.mac.com/egpaterson-Public
It is the only file there. Also, I mistyped my original email. This grid was designed for sublayer resolution.
Eric
Old   November 27, 2006, 04:55
Default I get a nice core dump over he
Hrvoje Jasak
I get a nice core dump over here:
--> FOAM FATAL ERROR : index 6 out of range 0 ... 5
It turns out that the cell number 182, defined as a hex, has got 7 (at least 7?) faces, which is wrong. The offending face index is 976015.
My guess is that you have defined a face of cell 182 to belong to two boundary patches at the same time. As usual, nothing wrong with my converter.
Hrv
Hrvoje Jasak
Old   November 27, 2006, 06:28
Default Thanks for the debug, Hrv. I'
egp
egp's Avatar
Eric Paterson
Thanks for the debug, Hrv. I'll double-check, but this would be impossible to explicitly do when using GridGen. Maybe there is a bug with the Gridgen -> Fluent converter, although I've not run into one before. I'll post back when I find the error.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
