[snappyHexMesh] AddLayers on an Airfoil
Old   March 27, 2012, 11:41
Default AddLayers on an Airfoil
Roberto Della Ratta
rdrr84 is on a distinguished road
Hi Foamers!
I have a problem in creating the Boundary Layer on an airfoil geometry with SHM.
The castellated and snappy phase are ok whereas "addLayers " results in no layer added. Could someone help me?
Thanks a lot
Roberto
I attach the snappyHexMeshDict and the log file for the addLayer phase
rdrr84 is offline   Reply With Quote
Old   March 27, 2012, 12:30
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Have you tried this (from your log):
Please set nGrow=0
lovecraft22 is offline   Reply With Quote
Old   March 28, 2012, 05:42
Roberto Della Ratta
Hi!
thx for your answer.
Yes I did it but no layer is added... I also changed the exp ratio to 0.1 to have a greater avg thickness.
Roberto
Old   March 28, 2012, 06:00
lore
I would suggest you to stick with the default parameters and then change only one of them at a time. Every time remember to get rid of every file mesh related.
For example, you set
expansionRatio 0.1;
and there's no point to me in setting this for an airfoil:
/------------------------------------------ Layer 3
| c
/------------------------------------------ Layer 2
| b
/------------------------------------------ Layer 1
|_a_______________________________
/////////////////////////////////////////// Wall
expansionRatio = c/b = b/a
The layers should grow in height when moving away from the wall. In your case they are getting smaller.
Also
finalLayerThickness 0.1;
doesn't make much of a sense to me…
Old   April 18, 2012, 06:06
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Do you need snappyHexMesh? If feasible for your airfoil you could use my little airfoil mesher, found here: http://hvirvel.dk/airfoilmesher/
Cheers,
Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   August 22, 2012, 02:46
Andreas Wendy
A.Wendy is on a distinguished road
i have a question to the airfoil mesher. the linked website to worldofkrauss is not working to see the example dat-file. maybe you can show one?
greetings
Andy
A.Wendy is offline   Reply With Quote
Old   August 22, 2012, 03:19
Retired Super Moderator
Bruno Santos
Greetings to all!
@Andy: Seems like the server for the worldofkrauss website is having bad luck. You can find some information here: http://www.rcgroups.com/forums/showt...3#post22118311 - it seems it was up again in July, but went down again now in August.
Best regards,
Bruno
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
