[snappyHexMesh] SnappyHexMesh - snapping the wrong elements
Old   September 24, 2012, 01:32
Question SnappyHexMesh - snapping the wrong elements
Andreas Wendy
A.Wendy is on a distinguished road
i am having a problem with the snapping Part in snappyHexMesh.
i try to Mesh a airfoil profile. The first step of SHM works fine and i get a nice Mesh. (picture 1+2) But when it comes to the snapping part SHM snapps the wrong Elements. (pictures 3+4) Instead of meshing the upper and lower elemnts it snapps the side elements. Has anyone an idea how i can fix this Problem? I think i have to modify the tolerance part in the SHMDicts but the result does not realy change. (tried 0,05 up to 4,0)
Best wishes
Andy
A.Wendy is offline   Reply With Quote
Old   September 25, 2012, 03:52
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by A.Wendy View Post
Best wishes
Andy
how is your snap-output? Can you put your log-file in there? I think there is a problem with many cells and sHM collapse that again couse of bad mesh result. For that problem, its possible to scale your mesh bigger - mesh it again - rescale it down.
Tobi
Tobi is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh not snapping to cylinder end wildfire230 OpenFOAM Meshing & Mesh Conversion 0 March 1, 2019 12:09
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
wrong zero boundary dir in parallel after snappyHexMesh HagenC OpenFOAM Pre-Processing 2 March 13, 2017 04:47
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 10:45
[snappyHexMesh] snappyHexMesh not snapping perfectly to surface and failing checkMesh Greg Givogue OpenFOAM Meshing & Mesh Conversion 5 February 28, 2011 11:43
