[blockMesh] Enhanced blockMesh for external aerodynamics
Old   December 5, 2012, 16:50
Default Enhanced blockMesh for external aerodynamics
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
I have written an enhanced blockMesh for the last few days, I am wondering if the developers want to include it or not.
The utility is now able to handle almost all single-object, non-concave, 2D external flow CFD mesh generation, flow around a 2D object. For example, an regular shape, or irregular polygon, or airfoil, etc.
The mesh generated is still multi-block mesh. But the burden on the user is much smaller.
The input needed now is something like:
|  \\    /   O peration     | Version:  2.1.x                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
twoDObject
// NACA Airfoil
    // Square
    // (0 0 0)
    // (1 0 0)
    // (1 1 0)
    // (0 1 0)
    // irregular
    (-2 -1 0)
    (-1.9 -1.2 0)
    (-2.2 -0.2 0)
    (1.2 -0.3 0)
    (1.2 -0.2 0)
    (2 0 0)
    (1.8 1 0)
    (0 2 0)
    (-2 1 0)
    // Concave
    // (-5 -1 0)
    // (-2 -3 0)
    // (2 -3 0)
    // (3 1 0)
    // (1 4 0)
    // (-3 0 0)
    // (-4 2 0)
xLimM   -40.0;
xLimP    50.0;
yLimM   -40.0;
yLimP    40.0;
zThik    0.5;
meshDensity     (1 100 1);
expRatios       (1 120 1);
refineLevel     5;
firstCellHeight 0.001;
isConcave       false;
AOA     90;
edges
mergePatchPairs
As can be seen, a few features:
1. You can define the object, just by its corners, and also no need to care about its orders.
2. You could set the first cell height.
3. You could set the mesh density as usual, but now you can even do it in a more simply way by setting mesh refine level, which refines the circumferential grid;
4. Angle of attach could be easily set (AOA);
5. The outer boundary (geometries and patch names and types) is done like a macro, you just need to set the x and y limits. (This is a rectangular outer boundary.)
Here are two figures,
Cheers,
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   December 6, 2012, 02:49
Christian Lucas
Chris Lucas is on a distinguished road
thanks for your work. If you want to share your code, you can publish it asstand alone application on openFoam wiki as Nils did with waves2FOAM (http://openfoamwiki.net/index.php/Contrib/waves2Foam).
You could also contact Hrvoje Jasak and ask if the code gets includes in OpenFOAM ext (http://www.extend-project.de/index.p...iew=department)
Kind Regards,
Christian Lucas
Chris Lucas is offline   Reply With Quote
Old   December 6, 2012, 11:41
lakeat's Avatar
Daniel WEI (老魏)
Thanks, I asked because it is not a standalone application, I changed the core library as well, including the constructor of blockMesh.
Daniel WEI
Beijing, China
Email
Old   December 10, 2012, 12:14
plucas's Avatar
Anonymous
plucas is on a distinguished road
Sorry if this is a dumb question, but is multiple airfoils possible with this enhanced blockMesh?
plucas is offline   Reply With Quote
Old   December 10, 2012, 13:23
lakeat's Avatar
Daniel WEI (老魏)
Not now, I tried to make it more able to handle multi-objects, but before doing that, I was hoping to have smoothing works first. After a few days of trial and error, the smoothing does work a little bit, but I found it not very efficient to write within OpenFOAM's framework, majorly because of the grid definition of each block descriptor, so I give up.
But I will keep this in mind (it is also one of my objectives) as I am currently looking for a better mechanism to replace OpenFOAM's native block descriptor.
Thanks though.
Daniel WEI
Beijing, China
Email
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Enhanced wall treatment and Enhanced wall functions Alina FLUENT 2 January 3, 2012 18:48
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
