May 2, 2013, 16:59 |
Netgen - News
Philippose Rajan
Rep Power: 25 |
Hello and a Good Evening,
I thought I would inform the group here of a few recent changes to Netgen which would be relevant to OpenFOAM users: 1. There now exists a CMake Build version of Netgen which compiles (hopefully) on Windows and Linux. This version can be found at: https://github.com/philippose/netgen-cmake As always, it would be great if errors in the build process / usage front could be reported.... either directly on Github, or here. The version on Github essentially mirrors the official Netgen release found at: http://sourceforge.net/projects/netgen-mesher/ 2. The capability to export OpenFOAM meshes directly from Netgen has existed for quite a while now, but today I added on the ability to also export the mesh in compressed ".gz" format. 3. The Netgen mesh export format "STL Extended" exports a surface mesh generated in Netgen into a single STL file, but with each boundary patch encapsulated into a separate "SOLID".... This makes it possible to use this export as an input into snappyHexMesh. In addition, the STL Mesh export now also supports exporting into ".stl.gz" format, which compresses the file using "gz". 4. Netgen now has an additional external dependency.... the "GZ" library. So for those of you who would like to compile Netgen (in either Windows or Linux) will need to have this library present on the system. Thats all for now :-)! Have a great evening ahead! Philippose |
Display Modes | |
[Gmsh] Patches in GmshToFoam | hannes | OpenFOAM Meshing & Mesh Conversion | 11 | March 8, 2013 09:01 |
[Netgen] Netgen - Queries Batchmode & Verbose Mode | shivaprasad123 | OpenFOAM Meshing & Mesh Conversion | 1 | July 17, 2011 12:06 |
[Netgen] Netgen segfaults tetmeshing on Redhat EL5 | djvictoid | OpenFOAM Meshing & Mesh Conversion | 1 | June 11, 2011 07:53 |
[Netgen] Geometry > Netgen > OpenFOAM | ericnutsch | OpenFOAM Meshing & Mesh Conversion | 9 | February 22, 2010 08:39 |
[Netgen] Netgen v45 Release Candidate 2 | philippose | OpenFOAM Meshing & Mesh Conversion | 2 | April 29, 2008 17:58 |
