[snappyHexMesh] Refinement Error in Cylindrical Tank |
May 14, 2013, 15:19 |
Eric Dalmau
Hey Foamers!
After having troubles with the MRFZone now I face the problems with the 3D case. I made an easy geometry, open cylinder as a tank with fluid in it (now is water). I have 2 different problems but the concern for this post is about the dynamic refinement. I add to my solver the lines for updating the mesh (it's already working when the fluid is moving out of the tank) but in some cases depending on the blockmeshdict, the dynamicMeshDict and snappyHexMeshDict parameters an error appears. I saw another post with the same error but someone told that has lack of info so I'll try to explain properly my case with images. Mesh at t=0: CheckMesh.log: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : checkMesh Date : May 14 2013 Time : 00:22:07 Host : "Ubuntu" PID : 10475 Case : /home/eric/PFC/DyM/Prova5 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 272970 faces: 782989 internal faces: 756336 cells: 255284 faces per cell: 6.02985 boundary patches: 2 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 243752 prisms: 6256 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 5276 Breakdown of polyhedra by number of faces: faces number of cells 4 16 5 180 6 1338 8 144 9 2703 11 18 12 765 14 2 15 108 18 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology paret 4752 4896 ok (non-closed singly connected) diposit_tanc 21901 22282 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.0500009 -0.1 -0.000122964) (0.15 0.1 0.2) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-4.38433e-17 3.57906e-16 3.58487e-16) OK. Max cell openness = 2.63571e-16 OK. Max aspect ratio = 10.2141 OK. Minimum face area = 1.07341e-07. Maximum face area = 0.000100237. Face area magnitudes OK. Min volume = 9.25195e-11. Max volume = 1.00226e-06. Total volume = 0.00785749. Cell volumes OK. Mesh non-orthogonality Max: 64.9435 average: 5.81975 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.79521 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
--> FOAM FATAL ERROR: nAnchors:2 faceI:119478 From function createInternalFaces(..) in file polyTopoChange/polyTopoChange/hexRef8.C at line 1276. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Foam::hexRef8::createInternalFaces(Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<int> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, int, Foam::polyTopoChange&) const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicMesh.so" #3 Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam::polyTopoChange&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicMesh.so" #4 Foam::dynamicRefineFvMesh::refine(Foam::List<int> const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so" #5 Foam::dynamicRefineFvMesh::update() in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so" #6 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/MRF3DInterDyMFoam" #7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #8 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/MRF3DInterDyMFoam" Avortat (bolcat de la imatge del nucli) I know that maybe the mesh is not as good as expected but with my laptop is the only way I can run the simulations. Anyone knows how to fix that error? Thanks, Eric |
December 18, 2015, 05:11 |
Stephanie
Rep Power: 11 |
Hello Eric,
I know your post is 2 years ago, but I got the same problem today. Did you fixed the error? best regards, Stephie |
February 18, 2016, 11:55 |
Cheng
Rep Power: 10 |
March 17, 2016, 08:10 |
#4 | |
Robert Castilla
I faced today the same problem. In my case it was because I was trying to make the sHM over a previous mesh. It worked after cleaning constant/polyMesh, running blockMesh and decomposing. Hope it will help. Regards Robert |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
