[snappyHexMesh] snappyHexMesh ignores refinement regions
Like Tree1Likes
  • 1 Post By kilroy
Old   June 7, 2013, 09:17
Default snappyHexMesh ignores refinement regions
kilroy's Avatar
kilroy is on a distinguished road
Hello all,
I trying to add refinement regions to my mesh by using snappyHexMesh but for some reason it doesn't let me do that.
You can see my "blockMeshDict" and "snappyHexMeshDict" files attached.
blockMeshDict.txt
snappyHexMeshDict.txt
I checked my "searchableBox" coordinates but nothing seems wrong.
Can you please help me to find the problem?
Thanks,
kilroy is offline   Reply With Quote
Old   June 8, 2013, 16:49
Retired Super Moderator
Bruno Santos
Greetings kilroy,
This tends to happen a lot with snappyHexMesh I personally end up not using layer addition by sHM and use refinement levels instead of layers.
Nonetheless, I suggest that you check the very useful presentation "A Comprehensive Tour of snappyHexMesh - 7th OpenFOAM Workshop (25 June 2012)" for more ideas: http://openfoamwiki.net/index.php/SnappyHexMesh
Best regards,
Bruno
Old   June 10, 2013, 14:02
kilroy's Avatar
Thank you very much for your reply Bruno. I found the problem now. It is because of my "blockMeshDict" file. I did a mistake with my vertices.
vertices
(-35 -0.04 -17.5)
( 55 -0.04 -17.5)
( 55 0.04 -17.5)
(-35 0.04 -17.5)
(-35 -0.04 17.5)
( 55 -0.04 17.5)
( 55 0.04 17.5)
(-35 0.04 17.5)
(-35 -0.04 17.5)
( 55 -0.04 17.5)
( 55 0.04 17.5)
(-35 0.04 17.5)
z-coordinate of the points above shown with red, should be zero.
After fixing that, my "snappyHexMesh" started working properly again
Sincerely,
Kilroy
wyldckat likes this.
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 03:59
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
