[snappyHexMesh] How to refine the edges?
Old   July 11, 2013, 11:26
Default How to refine the edges?
Thomas
Tomashek is on a distinguished road
Hi!
I have a problem with sharp edges. Which parameters should I change to get a better mesh? As you can see the object is not mesh very well even If I change the snapControls parameters.
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      autoHexMeshDict;
castellatedMesh true;
snap                 true;
addLayers         false;
geometry
    cube.stl
        type triSurfaceMesh;
	name cube;
castellatedMeshControls
    maxLocalCells 1500000;
    maxGlobalCells 2000000;
    minRefinementCells 0;
    nCellsBetweenLevels 2;
    features
        {file "cube.eMesh"; level 2;}
    refinementSurfaces
        cube
            level (1 2);
    resolveFeatureAngle 0;
    refinementRegions
    locationInMesh (2 2 2);
    allowFreeStandingZoneFaces true;
snapControls
    nSmoothPatch 15;
    tolerance 0.1;
    nSolveIter 300;
    nRelaxIter 15;
addLayersControls
    relativeSizes true;
    layers
    expansionRatio 1.1;
    finalLayerThickness 0.7;
    minThickness 0.1;
    nGrow 1;
    featureAngle 60;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.9;
    maxThicknessToMedialRatio 0.9;
    minMedianAxisAngle 130;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    nRelaxedIter 20;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 1e-13;
    minTetQuality 1e-30;
    minArea -1;
    minTwist 0.05;
    minDeterminant 0.001;
    minFaceWeight 0.05;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
    relaxed
        maxNonOrtho 75;
debug 0;
mergeTolerance 1E-6;
Tomashek is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
