[snappyHexMesh] Convert stl files and multi region
Old   May 30, 2014, 13:25
Default Convert stl files and multi region
Adrien Brunet
abrunet is on a distinguished road
I'm new to openfoam and python-vtk, so I'm not even sure I'm asking this at the right place..
I found the folllowing code to convert stl binary files to ascii files and the opposite. (I'm a noob with python-vtk)
#!/usr/bin/env python
import vtk
def convert_stl2ascii(path):
reader = vtk.vtkSTLReader()
reader.SetFileName(path)
reader.Update()
write = vtk.vtkSTLWriter()
write.SetFileTypeToASCII()
write.SetInput(reader.GetOutput())
write.SetFileName(path)
write.Write()
def convert_stl2binary(path):
reader.Update()
write.SetFileTypeToBinary()
write.SetFileName('_binary.stl'.join(path.split('. stl')))
write.Write()
Let's say I have a ascii stl file like this:
solid first_name
endsolid
solid second_name
endsolid
I can convert it to binary but when I try to convert it back to ascii, I get something like:
solid ascii
endsolid
What should I do to keep the Region name information and to avoid that several different region to be merged in only one region?
My aim is then to use openfoam and snappyhexmesh with that file (either the binary or ascii one). I need to convert the files because I start with a stl file uploaded by a user on a website, and I don't know what kind of stl file he will use. The easy way I found is to convert the file to binary and ascii regardless of its orignal type.
Hope my problem is clear and that you can help me.
Cheers
abrunet is offline   Reply With Quote
Old   July 1, 2014, 10:15
Default shm and multiregions
dzi
dzi is on a distinguished road
Hi
FYI i started another thread on SHM on multiregion foam.
http://www.cfd-online.com/Forums/ope...ns-salome.html
Regards dirk
dzi is offline   Reply With Quote
convert, python, snappyhexmesh, stl, vtk
[OpenFOAM] Post Processing Multi Region .OpenFOAM malix38 ParaView 2 April 1, 2019 20:44
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 10:25
[Other] Material properties in multi region foam and refining mesh for each region mukut OpenFOAM Meshing & Mesh Conversion 2 October 7, 2013 02:08
[snappyHexMesh] Multi Region Meshing bruce OpenFOAM Meshing & Mesh Conversion 12 July 31, 2013 10:09
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
