[Other] Plasma actuator induced flow simulation |
May 28, 2014, 09:52 |
Mominul MuKuT
Rep Power: 17 |
I am trying to simulate plasma induced flow based on suzen model . I already simulated the flow using PHOENICS by CHAM UK. The flow domain is as follows:
Now I am trying to simulate this using openfoam. I have posted regarding this few months ago in this forum and suggested to use multi regionFOAM for such solid-air domain. Then I have modified the multi region heater tutorical case as follows: Here dielectric material is Kapton and electrodes are cupper. How can I define the material? In my previous simulation using Phoenics, it found that both side plasma induced identical flow structure so now I think it should be reduced to as follows: Is it possible to make such geometry consist of solid-air domain by simple blockmesh? Or using muti region by toposet is okey? I have tried to make above flow domain by blockMESH but don't understand how to define the face of colored region. Here brown color represent electrodes and faded red color indicates dielectric material. I have chosen the left face of block1,4,7,13 are inlet, right face of block 3,6,9,12, 15 are outlet. top and bottom are as top and bottom wall respectively. and front & back are as usual empty. But how can I define color region? Thanks in advance. Last edited by mukut; May 28, 2014 at 09:55. Reason: resizing image |
May 29, 2014, 11:19 |
Mominul MuKuT
Rep Power: 17 |
Any suggestion??
May 31, 2014, 01:44 |
Mominul MuKuT
Rep Power: 17 |
anybody help me please......
geometry, mesh, openfoam, plasma actuator, suzen model |
parametric study in flow simulation | topaz | FloEFD, FloWorks & FloTHERM | 1 | July 13, 2015 08:50 |
how to get a time-accurate solution in Flow Simulation | drdet | FloEFD, FloWorks & FloTHERM | 4 | January 20, 2015 07:11 |
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? | alpharays | Main CFD Forum | 0 | April 19, 2012 03:13 |
Simulation of flow induced by plasma actuator | mukut | Phoenics | 0 | April 21, 2010 07:32 |
