Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
CfMesh Mesh Refinements
Like Tree1Likes
  • 1 Post By franjo_j
Old   May 29, 2015, 15:16
Default CfMesh Mesh Refinements
Calum Douglas
snowygrouch is on a distinguished road
In this case we`re talking car external aero. For which I`ve basically
copied the "asmoOctree" cf-mesh standard example and adapted it to my STL geometry.
(pics attached)
I made separate STLs, car_body, ground, walls, inlet, outlet etc etc
then joined into one STL file with cat command, and in ASCII format
renamed the patches inside the single large STL.
I cant see any obvious solutions to this in the official documentation - although
I suspect that #1 is something to do with this "fms" filetype. But its not very
clear to me how I get to that from the starting point of ASCII STLs.
My questions (in decending order of importance)
1) I do not want the side and upper walls etc to have mesh refinements.
How do I stop these patches getting refined ?
(pic from cfmesh example also attached showing it how I wish my mesh to appear)
https://drive.google.com/file/d/0B7a...ew?usp=sharing
2) In snappy I can easily make an additional box shaped refinement area (inside of the outer boundary STL box) behind the car to catch the wake eddies, Can this be done in CF-Mesh too ?
3) In snappy I make alot of use of distance refinements, so I can say how far away from my car I want each level of refinement to extend. Possible in Cf ?
My cfmesh config file:
| \\      /  F ield         | cfMesh: A library for mesh generation          |
|  \\    /   O peration     |                                                |
|   \\  /    A nd           | Author: Franjo Juretic                         |
|    \\/     M anipulation  | E-mail: franjo.juretic@c-fields.com            |
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
surfaceFile "car_all.stl";
maxCellSize 0.3; //0.2
boundaryCellSize 0.03;//0.025
minCellSize 0.015; //0.0125
localRefinement
    car_body
        cellSize 0.006; //0.005
    car_wheels
        cellSize 0.005; //0.0025
    car_tyres
        cellSize 0.005; //0.025
Thanks for your help !
Regards
Calum Douglas
Director
Scorpion Dynamics Ltd
Email: calum.douglas@scorpion-dynamics.com
Web: www.scorpion-dynamics.com
snowygrouch is offline   Reply With Quote
Old   May 29, 2015, 18:56
Default progress
Calum Douglas
I managed to sort out most of this - not sure I`m doing in a very good way - but I solved the first one by making the boundary cell density identical to the max cell size. I think maybe not ideal but works.
The 2nd issue actually was in the manual, I just didnt look properly.
However would still be very nice to find out how to NOT get the corners of the "wind-tunnel" to have angle corner refinements added....thats the current un-solved one now (see image below).
|  \\    /   O peration     |                                                |
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
surfaceFile "car.fms"; //"car_all.stl"
boundaryCellSize 0.3;//0.03  //make same as maxCellSize to get rid of walls being refined
localRefinement
    ground
        cellSize 0.025; //0.005
    car_body
    car_wheels
    car_tyres
// Next section added by Calum to refine zone behind the car -not tested yet
objectRefinements //copied from text in official manual
    wake_refine //zone behind car to capture wake
    type		box; //shape of zone
    cellSize		0.15; //wake cell size
    centre		(3 0 1.0); // xyz centre of box
    lengthX		10.0;
    lengthY		3.5;
    lengthZ		2.0;
// Next section added by Calum to add in viscous layers
boundaryLayers  //coped from example "singleorifice"
//    nLayers 3; //viscous layers to add
//    thicknessRatio 1.2; //1.0 > 1.3
//    maxFirstLayerThickness 0.0015; //meters
    patchBoundaryLayers
        "car_body"
            nLayers           3;
            thicknessRatio    1.2;
            allowDiscontinuity 0;
    	"car_wheels"
            nLayers           3;
            thicknessRatio    1.2;
    	"car_tyres"
            nLayers           3;
            thicknessRatio    1.2;
Calum Douglas
Director
Old   June 1, 2015, 08:03
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
cfMesh requires only two entries in meshDict, and these are surfaceFile, and maxCellSize. All other settings are optional. Therefore, you do not need boundaryCellSize entry if you do not need to refine the mesh at the boundary.
Refinement zones near corners and edges of the bounding box very likely come from the automatic refinement procedure activated by the minCellSize setting.
It is possible to use primitives i.e. (box, sphere, cone, line) as refinement sources. The syntax is documented in the manual.
Distance refinement is available, and is activated by specifying refinementThickness. Examples are provided in the manual. It is not parallelised in the version 1.0.1, and can be slow when the thickness is large. A new improved version shall be available soon.
Kind Regards,
Franjo
elvis likes this.
Principal Developer of cfMesh
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Google+, Facebook, Pinterest
franjo_j is offline   Reply With Quote
car, cfmesh, mesh, refinement
Thread Tools
Trackbacks are On
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
Propeller mesh not smooth nortanapura OpenFOAM Native Meshers: snappyHexMesh and Others 0 May 16, 2014 03:26
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
