[snappyHexMesh] Meshing a diffuser using snappyhex problem? |
July 11, 2015, 08:16 |
CFD
Rep Power: 16 |
Hello Foamers,
I hope that you all are well. I am new to openFoam. I am trying to mesh a diffuser inside a cube. I have created the stl file using solidworks and made sure that the diffuser is inside the blockMesh for the file that I have created using paraview. I have changed the patches inside the snappyhexmesh file to match the stl file. Furthermore, I have applied the following commands: 1- blockMesh 3- decompserdec 3- mpirun -np 6 snappyHexMesh -overwrite -parallel 4- reconstructParMesh -constant So far, I am unable to get any results. Please if anyone could find sometime to help me out in this regard. Thanks in advance, http://www.mediafire.com/download/3t...ffuser1.tar.gz Last edited by tareqkh; July 11, 2015 at 09:26. |
July 12, 2015, 04:21 |
Anybody have some time
CFD
Rep Power: 16 |
I have tried but noting has happened up until now...
Display Modes | |
3D Cyclone meshing problem | Wayne12195 | Mesh Generation & Pre-Processing | 0 | September 25, 2018 02:45 |
[ANSYS Meshing] problem in meshing of Aerofoil shaped obstacles in plane channel. | lohith | ANSYS Meshing & Geometry | 0 | June 20, 2018 03:58 |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 05:55 |
[ICEM] Meshing problem in Formula one | Far | ANSYS Meshing & Geometry | 113 | April 23, 2013 13:36 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 12:27 |
