[snappyHexMesh] Can Snappyhexmesh work with Prism cells? |
August 19, 2015, 06:16 |
Vineet Bhola
Rep Power: 10 |
Hi All,
I have always worked with snappyhexmesh alongwith blockmesh containing only hexahedral cells. But one of the demand that has come up from a customer is if I could use Prism cells instead of hex cells. My concerns are: 1. I saw on OPENFOAM user guide that instead of hex keyword, if I use prism, I can have prismatic cells. But my concern is that then the box itself would be a prism. I want to know if it is possible to have a cuboid as box and prism cells inside. 2. Suppose I find a solution to the first concern, is it then possible to work with prism cells in Snappyhexmesh? What parameters do I need to change for that? Thanks, Vneet |
August 19, 2015, 08:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers:
August 20, 2015, 08:13 |
Vineet Bhola
Rep Power: 10 |
Thanks for the clarification Bruno. You are right regarding prismatic boundary layer. My question now is,
Vineet ----- I mean "ncellsBetweenLevels" Last edited by wyldckat; August 20, 2015 at 15:04. Reason: merged posts that were a few minutes apart |
August 20, 2015, 15:10 |
Bruno Santos
Rep Power: 128 |
Quick answers:
August 25, 2015, 06:02 |
Vineet Bhola
Rep Power: 10 |
sorry for the delay in responding. I thought of first using the mesh generated by snappy for solver and if the results are accepted by customer then if needed try cfMesh. It seems that he is more concerned with gradually increasing boundary layers and bigger cells in center than the prismatic boundary layer itself.
If I have to use cfMesh later and find any problems, I will continue the discussion. (or start another post) btw, is there any way to track my own posts? I see an option of "new posts" OR "your blog" but not "your post" Thanks Vineet |
August 26, 2015, 19:19 |
#6 | ||
Bruno Santos
Rep Power: 128 |
Quick answers:
Display Modes | |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 10:12 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same | kanes | OpenFOAM Meshing & Mesh Conversion | 0 | January 25, 2016 09:06 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
