[snappyHexMesh] Internal and External flow in SnappyHexMesh
Old   September 11, 2015, 04:25
Default Internal and External flow in SnappyHexMesh
selvavm is on a distinguished road
Dear Friends,
I am new to OpenFOAM and I have doubt.
My case is a thick hollow cylinder rotating around an axis. I added the cylinder.stl to refinement surface in snappyhexmesh dict and after meshing I could see that only the outer surface of the cylinder is meshed with block mesh and internal channel is void (no cells)
So, I created one more channel.stl (same dimension as the inside of the cylinder), and added that to refinement region. Then, Only one face of the channel.stl exposed to free stream is meshed but the channel region is still not meshed
Could you please help me in this?
Also, If there is any other way to mention both Internal and External flow in snappyhexmesh please let me know.
I will be waiting for your replies.
EDIT: From guide, I found that cell removal depends on locationinmesh parameter. Now, I am confused what value to give
Is there any way to give two locationinmesh so that cells are removed from the cylinder except on the channel?
Thanks,
Selva
selvavm is offline   Reply With Quote
Old   September 12, 2015, 04:02
M. C.
student666 is on a distinguished road
Can you post a picture or two of your domain?
Can you give more details about the simulation you're planning to run?
student666 is offline   Reply With Quote
Old   September 12, 2015, 20:42
Hey,
Thanks for replying. I don't have my case data now, but I can explain the same thing with motorbike tutorial.
When I ran the snappyhexmesh in motorbike tutorial, I am able to see there is void space in bike's wheel rim (with paraview's wireframe view on Bike).
Now my doubt is, whether the grid missing in the rim, is due to my setting in paraview to display only bike?
I mean, if the enclosing object (in my case a box surrounding the motorbike) has grids in it (assuming very fine grid), then that means gaps in model also has grid? That is, does fluid can flow through the rim gap?
Thanks a lot
Regards,
Selva
Old   September 13, 2015, 04:39
M. C.
Ok, is it right to say that you have meshing problem on small gaps?
In any case, before we go further with discussion is better to discuss within your case?
It's already hard to understand sometimes others people problem, and speaking about a case to relate to one other: I think it's crazy.
For example: I could suggest you to merge two meshes (look at sourceflux for a tutorial) and create interfaces between them (cyclic or cyclic AMI), but I don't know if you really need it and I can lead you to the wrong way, not allowing you to solve the problem.
the more specific you are, the more you can get help from other people in the forum.
Regards
cylinder mesh, mesh 3d, openfoam, pimpledymfoam, snappyhexmesh
Difference between External and Internal flow radiation problems Kummi FLUENT 0 April 10, 2018 03:06
External flow or Internal flow boundary domain dinhanh Main CFD Forum 0 June 4, 2017 06:43
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh denner OpenFOAM Meshing & Mesh Conversion 3 October 13, 2011 09:24
internal flow and external flow ? Pathway0320 FLUENT 1 November 17, 2006 03:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
