Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Cylindrical blockmesh to Improve snappyHexMesh Results
Old   October 13, 2015, 18:51
Default Cylindrical blockmesh to Improve snappyHexMesh Results
nicholas.jones is on a distinguished road
All,
I have been trying to use a cylindrical blockMesh to improve my snappyHexMesh results. An example blockMesh is attached. I find that coarse simple blockMeshes results in holes when two surfaces of my .stl files become close together (also attached). I can use a finer blockMesh, but I get very large meshes as a result. I am hoping there is a more elegant solution!
Although the initial blockMesh looks good, I receive an error from snappyHexMesh, citing the following:
Shell refinement iteration 0
Marked for refinement due to distance to explicit features : 0 cells.
Marked for refinement due to refinement shells : 0 cells.
--> FOAM FATAL ERROR:
Illegal maxFaceDiff 0
Value should be >= 1
From function hexRef8::consistentSlowRefinement(const label, const labelList&, const labelList&, const label, const labelList&)
in file polyTopoChange/polyTopoChange/hexRef8.C at line 2370.
FOAM exiting
Google has very few illegal maxFaceDif 0 errors, so im hoping someone here might have an idea.
Should I persue this strategy to improve my snappyHexMeshes, or am I better off sticking with a simple blockMesh?
The code I use to generate cylindrical meshes is below (thanks to the folks at CFD-Online back in 2006, this code is excellent!):
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
changecom(//)changequote([,])
define(calc, [esyscmd(perl -e 'printf ($1)')])
define(VCOUNT, 0)
define(vlabel, [[// ]Vertex $1 = VCOUNT define($1, VCOUNT)define([VCOUNT], incr(VCOUNT))])
convertToMeters 0.00001;
define(D, 6693) //6.693 mm column diameter
define(L, 30000) //30 cm length
define(PI, 3.14159265)
define(R, calc(D/2))
define(CW, calc(D/4)) //Width of middle square section
define(CX, calc(R*cos((PI/180)*45)))
define(CZ, calc(R*sin((PI/180)*45)))
define(NPS, 10) //how many cells in the square section
define(NPD, 15) //how many cells from square section to perimeter
define(NPY, 15) // how many cells from top to bottom
vertices
( CW 0.0 CW) vlabel(fiveoclocksqb)
(-CW 0.0 CW) vlabel(sevenoclocksqb)
(-CW 0.0 -CW) vlabel(elevenoclocksqb)
( CW 0.0 -CW) vlabel(oneoclocksqb)
( CX 0.0 CZ) vlabel(fiveoclockcb)
(-CX 0.0 CZ) vlabel(sevenoclockcb)
(-CX 0.0 -CZ) vlabel(elevenoclockcb)
( CX 0.0 -CZ) vlabel(oneoclockcb)
( CW L CW) vlabel(fiveoclocksqt)
(-CW L CW) vlabel(sevenoclocksqt)
(-CW L -CW) vlabel(elevenoclocksqt)
( CW L -CW) vlabel(oneoclocksqt)
( CX L CZ) vlabel(fiveoclockct)
(-CX L CZ) vlabel(sevenoclockct)
(-CX L -CZ) vlabel(elevenoclockct)
( CX L -CZ) vlabel(oneoclockct)
blocks
//square block
hex (
sevenoclocksqb fiveoclocksqb oneoclocksqb elevenoclocksqb
sevenoclocksqt fiveoclocksqt oneoclocksqt elevenoclocksqt
(NPS NPS NPY)
simpleGrading (1 1 1)
//slice1
hex (
sevenoclockcb fiveoclockcb fiveoclocksqb sevenoclocksqb
sevenoclockct fiveoclockct fiveoclocksqt sevenoclocksqt
(NPS NPD NPY)
//slice2
hex (
sevenoclocksqb elevenoclocksqb elevenoclockcb sevenoclockcb
sevenoclocksqt elevenoclocksqt elevenoclockct sevenoclockct
(NPS NPD NPY)
//slice3
hex (
elevenoclocksqb oneoclocksqb oneoclockcb elevenoclockcb
elevenoclocksqt oneoclocksqt oneoclockct elevenoclockct
(NPS NPD NPY)
//slice4
hex (
oneoclocksqb fiveoclocksqb fiveoclockcb oneoclockcb
oneoclocksqt fiveoclocksqt fiveoclockct oneoclockct
(NPS NPD NPY)
//create the quarter circles
edges
arc fiveoclockcb sevenoclockcb (0.0 0.0 R)
arc sevenoclockcb elevenoclockcb (-R 0.0 0.0)
arc elevenoclockcb oneoclockcb (0.0 0.0 -R)
arc oneoclockcb fiveoclockcb (R 0.0 0.0)
arc fiveoclockct sevenoclockct (0.0 L R)
arc sevenoclockct elevenoclockct (-R L 0.0)
arc elevenoclockct oneoclockct (0.0 L -R)
arc oneoclockct fiveoclockct (R L 0.0)
boundary
Inlet
type patch;
faces
(fiveoclocksqb oneoclocksqb elevenoclocksqb sevenoclocksqb)
(fiveoclocksqb fiveoclockcb oneoclockcb oneoclocksqb)
(fiveoclockcb fiveoclocksqb sevenoclocksqb sevenoclockcb)
(sevenoclocksqb elevenoclocksqb elevenoclockcb sevenoclockcb)
(oneoclocksqb oneoclockcb elevenoclockcb elevenoclocksqb)
Outlet
type patch;
faces
(fiveoclocksqt oneoclocksqt elevenoclocksqt sevenoclocksqt)
(fiveoclocksqt fiveoclockct oneoclockct oneoclocksqt)
(fiveoclockct fiveoclocksqt sevenoclocksqt sevenoclockct)
(sevenoclocksqt elevenoclocksqt elevenoclockct sevenoclockct)
(oneoclocksqt oneoclockct elevenoclockct elevenoclocksqt)
Walls
type wall;
faces
(sevenoclockcb fiveoclockcb fiveoclockct sevenoclockct)
(sevenoclockcb sevenoclockct elevenoclockct elevenoclockcb)
(elevenoclockcb elevenoclockct oneoclockct oneoclockcb)
(oneoclockcb oneoclockct fiveoclockct fiveoclockcb)
mergePatchPairs
snappyHexMeshDict is attached:
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry
Balls.stl {type triSurfaceMesh; name Balls;}
castellatedMeshControls
maxLocalCells 10000000;
maxGlobalCells 70000000;
minRefinementCells 10;
nCellsBetweenLevels 0;
features
// {file "Inlet.eMesh"; level 2;}
// {file "Outlet.eMesh"; level 2;}
// {file "Balls.eMesh"; level 2;}
// {file "Walls.eMesh"; level 2;}
refinementSurfaces
Balls {level (1 2);}
resolveFeatureAngle 30;
refinementRegions
//refinementBox
// mode inside;
// levels ((1E15 4));
locationInMesh (0.01519 0.00008 0.18982);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 3;
tolerance 1;
nSolveIter 30;
nRelaxIter 5;
//- Highly experimental and wip: number of feature edge snapping
// iterations. Leave out altogether to disable.
// Of limited use in this case since faceZone faces not handled.
//nFeatureSnapIter 10;
//- Detect (geometric) features by sampling the surface
implicitFeatureSnap false;
//- Use castellatedMeshControls::features
explicitFeatureSnap false;
//- Detect features between multiple surfaces
// (only for explicitFeatureSnap, default = false)
multiRegionFeatureSnap false;
addLayersControls
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
"Balls"
nSurfaceLayers 40;
// Expansion factor for layer mesh
expansionRatio 1.05;
// Wanted thickness of final added cell layer. If multiple layers
// is the thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
finalLayerThickness 0.1;
// Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.001;
// If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
// Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
nGrow 1;
// Advanced settings
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 70;
// Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 2;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 1;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 1;
// Angle used to pick up medial axis points
// Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
minMedianAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations. The mesher will exit
// if it reaches this number of iterations; possibly with an illegal
// mesh.
nLayerIter 50;
// Max number of iterations after which relaxed meshQuality controls
// get used. Up to nRelaxIter it uses the settings in meshQualityControls,
// after nRelaxIter it uses the values in meshQualityControls::relaxed.
nRelaxedIter 5;
meshQualityControls
#include "meshQualityDict"
relaxed
maxNonOrtho 75;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Write flags
writeFlags
scalarLevels // write volScalarField with cellLevel for postprocessing
layerSets // write cellSets, faceSets of faces in layer
layerFields // write volScalarField for layer coverage
mergeTolerance 1E-6;
File Type: jpg Screenshot from 2015-10-01 19:29:17.jpg (157.9 KB, 52 views)
File Type: jpg Screenshot from 2015-10-13 18:49:17.jpg (106.1 KB, 44 views)
nicholas.jones is offline   Reply With Quote
Old   October 14, 2015, 14:10
All,
The error was originating from the snappyHexMeshDict. The cylindrical blockMeshDict m4 is helpful in improving my mesh, any may be a more effective solution for this kind of problem.
Old   January 2, 2018, 14:14
Tscar is on a distinguished road
May I ask how exactly did you solve this issue?
Tscar is offline   Reply With Quote
Thread Tools
Trackbacks are On
SnappyHexMesh with local refinement of ONE STLfile wolle1982 OpenFOAM Mesh Utilities 17 July 28, 2017 07:35
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 9 June 22, 2011 18:59
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
Parallel case setup boundry conditions snappyhexmesh oskar OpenFOAM Pre-Processing 5 September 11, 2009 01:12
