Multi-region Blockmesh - Refinemesh issues.
1 Attachment(s)
Sorry please ignore I posted this in the wrong sub-forum. ========================================== Hi All, I am getting stuck with running Refinemesh on a region created by Blockmesh My blockMeshDict file is attached, I don't think that there is an issue in it though, at the moment its just a simple case to try and get the method working. So there are 2 boxes Region01 and Region02 sharing common vertices at one face and with an identical type of mesh in both boxes. This runs, all good so far... Under constant\polyMesh\sets it creates Region01.gz and Region02.gz Then I attempt to run: refinemesh -region Region02 And get the error: --> FOAM FATAL ERROR: Cannot find file "points" in directory "Region02/polyMesh" in times 0 down to constant I thought that the files contained in Region01.gz and Region02.gz might be the points files but they do not look correct to be that. In the UserGuide.pdf section 5.1.2 "The polyMesh description" describes points as: a list of vectors describing the cell vertices, where the first vector in the list represents vertex 0, the second vector represents vertex 1, etc.; I can't see how to get the system to create this file though, it does not appear to be an option in blockmeshdict for example, any ideas or am I going the wrong direction completely? ========================================== Sorry please ignore I posted this in the wrong sub-forum. ========================================== |
