[snappyHexMesh] Snappy extruding my .stl file through my blockMesh |
May 23, 2016, 15:16 |
Abigail Stehno
Rep Power: 10 |
I am trying to place a floating box (.stl file) into a larger box (blockMesh file) using snappyHexMesh.
The problem is that the floating box cuts through the entire blockMesh, creating a rectangular hole in the mesh rather than a floating box. The dimensions of the blockMesh are x=0:8.5 , y=-1:1 , z= 0:0.9 and the dimensions of the floating box are x=4:5 , y=0:0.4 , z= 0.2:0.5 so the floating box should be within the confines of the original mesh Thanks in advance for any suggestions and help! |
May 24, 2016, 21:21 |
Abigail Stehno
Rep Power: 10 |
I have solved my problem- I was working in a 2D mesh in the y direction!
mesh, openfoam 2.3.0, snappyhexmesh |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
