[snappyHexMesh] snappy not using all refinementRegions and refinementSurfaces
Old   June 6, 2016, 06:20
Exclamation snappy not using all refinementRegions and refinementSurfaces
Suryansh D Kumar
suryansh is on a distinguished road
Hi
I am an absolute beginner to OpenFOAM. I am trying to load a geometry made of multiple STL files into snappy.
surfaceFeatureExtract has detected sharp edges and eMesh files have been generated.
But when I run snappyHexMesh, I get the following errors
Reading refinement surfaces.
--> FOAM Warning :
From function refinementSurfaces::refinementSurfaces(..)
in file autoHexMesh/refinementSurfaces/refinementSurfaces.C at line 226
Reading "/..../system/snappyHexMeshDict.castellatedMeshControls.refineme ntSurfaces" from line 151 to line 204
Not all entries in refinementSurfaces dictionary were used. The following entries were not used :
6
list of stl files/ patchnames
Reading refinement shells.
--> FOAM Warning :
From function shellSurfaces::shellSurfaces(..)
in file autoHexMesh/shellSurfaces/shellSurfaces.C at line 420
Reading "/../system/snappyHexMeshDict.castellatedMeshControls.refineme ntRegions" from line 218 to line 219
Not all entries in refinementRegions dictionary were used. The following entries were not used : 1
(name of stl)
Read refinement shells in = 0 s
Because of this, snappy crashes
[1] --> FOAM FATAL IO ERROR:
[1] Expected a '(' while reading Tuple2, found on line 0 the doubleScalar 0
[1]
[1] file: IOstream.castellatedMeshControls.features.levels at line 0.
[1]
[1] From function Istream::readBegin(const char*)
[1] in file db/IOstreams/IOstreams/Istream.C at line 94.
[1]
FOAM parallel run exiting
[1]
The mesh generated by blockMesh is pretty huge and all STL files are well inside it.
Please help. Thanks in advance
suryansh is offline   Reply With Quote
refinement regions, refinementsurfaces, snappy hex mesh, snappyhexmeshdict
[snappyHexMesh] Snappy creates strange cells far away from boundary vainilreb OpenFOAM Meshing & Mesh Conversion 3 December 16, 2020 05:11
[snappyHexMesh] snappy works but does not add layers...why? sandy13 OpenFOAM Meshing & Mesh Conversion 33 November 19, 2020 15:23
[snappyHexMesh] unsteady flow around a square cylindier snappy problems triball OpenFOAM Meshing & Mesh Conversion 4 February 20, 2016 16:10
[snappyHexMesh] Very BIG problem with snappy Yuby OpenFOAM Meshing & Mesh Conversion 1 April 30, 2015 15:53
[snappyHexMesh] refinementRegions ignored Jeanp OpenFOAM Meshing & Mesh Conversion 3 June 12, 2014 05:05
