June 30, 2016, 09:30 |
ShM: problems at sharp edges
Joris C.
Rep Power: 13 |
When using snappyHexMesh to mesh domains with sharp corners, the mesh does not resolve the edges: the mesh goes out of the domain. The direction in which it goes is not controllable, i.e. sometimes it messes up sides on which I want to apply e.g. a wedge BC, which needs a planar mesh.
An example result is in the attachment, along with a screenshot of the feature edges. At one point I've read: "If you have a problem with the bad cells you can change the snappyHexMesh settings to improve them at the expense of poorer surface and edge conformance." [http://bugs.openfoam.org/view.php?id=2099] but I don't know why.. I've tried OFv3+ for this feature:
Any ideas how to fix this? |
July 11, 2016, 21:23 |
Rep Power: 24 |
Can you post your mesh dictionary?
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] problems with sHM: it doesn't snap! | Claudio87 | OpenFOAM Meshing & Mesh Conversion | 25 | July 10, 2020 08:06 |
Modelling a flow around a square (with sharp edges) | Andy_ilek | OpenFOAM Pre-Processing | 1 | September 28, 2015 02:44 |
[snappyHexMesh] sHM, 2D, foils, sharp edge | skeptik | OpenFOAM Meshing & Mesh Conversion | 23 | August 12, 2013 06:38 |
[snappyHexMesh] Problems with multi-region mesh in sHM | Artur | OpenFOAM Meshing & Mesh Conversion | 0 | July 16, 2013 08:52 |
