[snappyHexMesh] Openfoam snappyhexmesh addLayersControls - non uniform layer |
July 19, 2016, 14:37 |
Almond Wong
Rep Power: 9 |
I am learning to add layers so as to improve y+ for the use of wall functions. I am using the windaroundbuildings file in the OF tutorials as a base case. I followed this thread closely: http://www.cfd-online.com/Forums/ope...defined-2.html I used both the feature and split angle speficied. But explicit feature snap was used instead in this case. After generating sHM, the layers generated was not uniform, it is good in some areas and bad in some. I have attached a picture to show the good (circled in green) and bad (circled in red). Can anyone explain why does this happen? Also, what is the slipFeatureAngle used for? |
July 19, 2016, 14:39 |
Almond Wong
Rep Power: 9 |
this is the sHMD used:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg" castellatedMesh true; snap true; addLayers true; geometry { buildings.obj { type triSurfaceMesh; name buildings; } refinementBox { type searchableBox; min ( 0 0 0); max (250 180 90); } }; castellatedMeshControls { features ( { file "buildings.eMesh"; level 1; } ); refinementSurfaces { buildings { level (3 3); patchInfo { type wall; } } } refinementRegions { refinementBox { mode inside; levels ((1E15 2)); } } locationInMesh (1 1 1); } snapControls { explicitFeatureSnap true; implicitFeatureSnap false; } addLayersControls { layers { "buildings.*" { nSurfaceLayers 8; } } relativeSizes false; expansionRatio 1.1; // Wanted thickness of final added cell layer. If multiple layers // is the // thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. // firstLayerThickness 0.05; can use first as well finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0; nGrow 0; // was 1 // Advanced settings featureAngle 330; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle. // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 5;//fix nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 1; // Number of smoothing iterations of surface normals nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction nSmoothThickness 10; // Smooth layer thickness over surface patches maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 130; // Angle used to pick up medial axis points nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 50; // Overall max number of layer addition iterations } meshQualityControls { } writeFlags ( scalarLevels layerSets layerFields ); mergeTolerance 1e-6; // ************************************************************************* // |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 10:56 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 06:59 |
Too high omega and k values in vortex flow simulation | thomas. | OpenFOAM Running, Solving & CFD | 9 | March 30, 2016 06:45 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
