[snappyHexMesh] Feature Request: Snappy Hex Step |
August 19, 2016, 15:24 |
Brenda EM
Rep Power: 14 |
Because .stp files are the defacto standard for surface definition, it would be a great advantage if OpenFoam could convert .Step brep surfaces directly from separate files to each represent boundaries in a simulation.
Snappy Hex Step would test to see if the result is manifold and airtight. The name of the step file becomes the boundary name that are used in the preprocessor files. There would be great advantages to doing this: 1.) We don't have to needlessly create an intermediate mesh. 2.) We have smaller file and project sizes because there are less intermediate files. 3.) Most 3D design and CAD programs, both closed as well as open sourced can use .stp. 4.) Because we aren't reinterpreting a mesh, accuracy may be better than the methods that are in use. 5.) In a landscape of few open front-ends, OpenFoam will become more accessible than it is now. 6.) Problems with source mesh integrity will not exits. 7.) Users and researchers may better focus on the research, with less attention needed to workflow and process. 8.) People will have fewer problems to ask for help with in these forums. For instance, the user would save out:L car.stp road.stp outlet.stp walls.step And then set up the initial conditions, and run SnappyHexStep, and then run OpenFoam to solve. Thanks for your consideration, Brenda Ellen Make |
December 22, 2018, 17:10 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick notes: Following up on old posts of yours, because I was looking for the one about non-orthogonal meshes, I noticed this one and I moved it to the snappyHexMesh sub-forum.
The notes I want to leave here are as follows:
Last edited by wyldckat; December 22, 2018 at 17:11. Reason: "they" -> "their supporters would" |
[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20) | robingilbert | OpenFOAM Meshing & Mesh Conversion | 28 | November 23, 2023 06:32 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
[snappyHexMesh] Snappy Hex Mesh External Domain | willindsey | OpenFOAM Meshing & Mesh Conversion | 2 | June 9, 2017 22:03 |
