[snappyHexMesh] create two faceZones with single STL file - is it possible? |
September 19, 2016, 16:30 |
Rep Power: 17 |
Hello all,
I am meshing an automotive radiator duct. Currently, I create a porous media cellZone with a single faceZone in snappyHexMesh, and then I use topoSet to split that faceZone into two faceZones: an inlet and outlet. The geometry for the faceZones must be in one STL file, so that the volume for the cellZone is properly closed. However, I would like to generate the inlet/outlet faceZones directly from the beginning, instead of running topoSet as an additional step. Does anyone know if this is possible? So far, all I can do is generate patches, which while convertible to a faceZone, do not allow the prism layers to travel through (something we need.) My attempt: Code:
geometry { A_testcar_5050.stl { type distributedTriSurfaceMesh; distributionType independent; name A_testcar_5050; regions { WALL_L_POROUS_Radiator_8_8 { name wall_l_porous_radiator; } WALL_L_body_8_8 { name wall_l_body; } WALL_L_body_small_2_2 { name wall_l_body_small; } } } internal_fluid_l_porous_radiator.stl { type triSurfaceMesh; name internal_fluid_l_porous_radiator; regions { INTERFACE_L_POROUS_radiator_inlet { name internal_l_porous_radiator_inlet; } INTERFACE_L_POROUS_radiator_outlet { name internal_l_porous_radiator_outlet; } } } }; // Castellated Mesh settings castellatedMeshControls { ...... refinementSurfaces { A_testcar_5050 { level (8 8); regions { WALL_L_POROUS_Radiator_8_8 { level (7 7); } WALL_L_body_8_8 { level (7 7); } WALL_L_body_small_2_2 { level (9 9); } } } internal_fluid_l_porous_radiator { level (8 8); cellZone fluid_l_porous_radiator; cellZoneInside inside; regions { INTERFACE_L_POROUS_radiator_inlet { type faceZone; faceZone internal_l_porous_radiator_inlet; faceType internal; level (8 8); } INTERFACE_L_POROUS_radiator_outlet { type faceZone; faceZone internal_l_porous_radiator_outlet; faceType internal; level (8 8); } } } } |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
