[snappyHexMesh] SHM is not extruding/adding Layers everywhere |
October 13, 2016, 17:52 |
Matthias D
Rep Power: 10 |
Hi everybody,
I am trying to mesh a terrain surface with snappyHexMesh (SHM). As far as I can tell, the steps of castellating and snapping the mesh are working fine. I have included the output of checkMesh for the different steps. The only slightly wired thing is the bounding box of the mesh after the snapping: Code:
Checking geometry... Overall domain bounding box (-2.80928364337e-11 -2.86651979204e-11 -1.91131555027e-09) (83300 76950 10000) The bigger problem seems to be the layer addition: Code:
Layer addition iteration 0 -------------------------- Determining displacement for added points according to pointNormal ... Detected 0 points with point normal pointing through faces. Reset displacement at 0 points to average of surrounding points. displacementMedialAxis : Smoothing using Medial Axis ... displacementMedialAxis : Reducing layer thickness at 0 nodes where thickness to medial axis distance is large displacementMedialAxis : Removing isolated regions ... displacementMedialAxis : Number of isolated points extrusion stopped : 0 displacementMedialAxis : Smoothing field ... Iteration 0 residual 2.74267968847e-16 displacementMedialAxis : Moving mesh ... displacementMedialAxis : Iteration 0 Moving mesh using displacement scaling : min:1 max:1 Checking faces in error : non-orthogonality > 70 degrees : 1 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Iteration 1 Moving mesh using displacement scaling : min:0.75 max:1 Checking faces in error : non-orthogonality > 70 degrees : 1 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Iteration 2 Moving mesh using displacement scaling : min:0.5625 max:1 Checking faces in error : non-orthogonality > 70 degrees : 1 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Iteration 3 Moving mesh using displacement scaling : min:0.421875 max:1 Checking faces in error : non-orthogonality > 70 degrees : 1 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Iteration 4 Moving mesh using displacement scaling : min:0.31640625 max:1 Checking faces in error : non-orthogonality > 70 degrees : 1 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Iteration 5 displacementMedialAxis : Displacement scaling for error reduction set to 0. Moving mesh using displacement scaling : min:0.2373046875 max:1 Checking faces in error : non-orthogonality > 70 degrees : 1 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Iteration 6 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : non-orthogonality > 70 degrees : 0 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 displacementMedialAxis : Successfully moved mesh displacementMedialAxis : Finished moving mesh ... truncateDisplacement : Unextruded 0 faces due to non-consecutive vertices being extruded. truncateDisplacement : Unextruded 1 faces due to stringed edges with inconsistent extrusion. truncateDisplacement : Unextruded 0 faces due to non-consecutive vertices being extruded. truncateDisplacement : Unextruded 0 faces due to stringed edges with inconsistent extrusion. Setting up information for layer truncation ... Checking mesh with layer ... Checking faces in error : non-orthogonality > 70 degrees : 0 faces with face pyramid volume < 1e-30 : 0 faces with face-decomposition tet quality < -1 : 0 faces with concavity > 80 degrees : 0 faces with area < 1e-30 m^2 : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 Detected 0 illegal faces (concave, zero area or negative cell pyramid volume) Extruding 2557541 out of 2557543 faces (99.9999217999%). Removed extrusion at 0 faces. Added 2557541 out of 2557543 cells (99.9999217999%). Edge intersection testing: Number of edges : 38571469 Number of edges to retest : 0 Number of intersected edges : 5101041 patch faces layers overall thickness [m] [%] ----- ----- ------ --- --- domain 2557543 1 15 10 And in the end it is only extruding 2557541 out of 2557543 faces, missing two faces. Which is kind of close, but unfortunately not good enough for my case... Here are the layer and the quality settings of the snappyHexMeshDict: Code:
// Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; nMedialAxisIter 10; // Per final patch (so not geometry!) the layer information layers { domain { nSurfaceLayers 1; } } // Expansion factor for layer mesh expansionRatio 1.1; //- Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. //finalLayerThickness 0.8; firstLayerThickness 0.3; //- Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.001; //- If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. nGrow 0; // Advanced settings //- When not to extrude surface. 0 is flat surface, 90 is when two faces // make straight angle. featureAngle 180; // 60 //slipFeatureAngel 90; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; //5; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // 10 // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.6; // 0.5 // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.6; // 0.3 // Smooth layer thickness over surface patches nSmoothThickness 10; // Angle used to pick up medial axis points minMedianAxisAngle 130; // 90 // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations nLayerIter 1; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 70; // 65; //- Max skewness allowed. Set to <0 to disable. maxBoundarySkewness 20; //20 maxInternalSkewness 4; //4 //- Max concaveness allowed. Is angle (in degrees) below which concavity // is allowed. 0 is straight face, <0 would be convex face. // Set to 180 to disable. maxConcave 80; // 80; //- Minimum projected area v.s. actual area. Set to -1 to disable. minFlatness 0.5; // 0.5; //- Minimum pyramid volume. Is absolute volume of cell pyramid. // Set to a sensible fraction of the smallest cell volume expected. // Set to very negative number (e.g. -1E30) to disable. minVol 1e-30; //- Minimum face area. Set to <0 to disable. minArea 1e-30; //- Minimum face twist. Set to <-1 to disable. dot product of face normal //- and face centre triangles normal //minTwist 0.02; minTwist -1; //- minimum normalised cell determinant //- 1 = hex, <= 0 = folded or flattened illegal cell minDeterminant -1; //0.001; //- minFaceWeight (0 -> 0.5) minFaceWeight -1; //0.02; //- minVolRatio (0 -> 1) minVolRatio -1; //0.01; //must be >0 for Fluent compatibility minTriangleTwist -1; //Added for 2.1.x, no clue what should be used here... minTetQuality -1; //1e-30; // -1 // Advanced //- Number of error distribution iterations nSmoothScale 4; //- amount to scale back displacement at error points errorReduction 0.75; relaxed { maxNonOrtho 75; } } Thanks a lot and let me know if you need any further information. Matthias |
October 15, 2016, 19:46 |
Anonymouse
Rep Power: 10 |
I'm sorry, could you be clearer on what exactly the problem is? Does your mesh look wrong or something?
October 16, 2016, 16:45 |
#3 | |
Matthias D
Rep Power: 10 |
Hi, thanks for your response! And sorry if I made a bad job explaining my problem. My problem is: SnappyHexMesh does not extrude and add a layer for every face. I only miss a few faces, but this is a problem in my case, as I need two perfectly parallel faces at the surface in order to calculate surface layer fluxes. Without those layers my solver will crash. Thank you in advance for every hint and help! |
[snappyHexMesh] adding layers on complex terrain surface in SHM | potac | OpenFOAM Meshing & Mesh Conversion | 1 | November 9, 2020 06:40 |
[snappyHexMesh] Fail to create boundary layers during sHM | farahiam | OpenFOAM Meshing & Mesh Conversion | 13 | October 15, 2014 19:46 |
[snappyHexMesh] SHM no layers added | student666 | OpenFOAM Meshing & Mesh Conversion | 7 | May 15, 2014 05:51 |
[snappyHexMesh] Effect of adding layers with sHM | Nucleophobe | OpenFOAM Meshing & Mesh Conversion | 4 | August 20, 2012 16:45 |
[snappyHexMesh] sHM layers problem | bgarrood | OpenFOAM Meshing & Mesh Conversion | 0 | February 16, 2012 05:07 |
