arsalan.dryi |
November 14, 2016 16:01 |
Sphere in a channel by snappyHexMesh
1 Attachment(s)
Dear Foamers,
I want to mesh a sphere inside a channel in both regions of inside and outside of the sphere. For this purpose, I'm trying to mesh these regions separately using sHM and merge them using mergeMesh.( Do you have any better suggestion??!)
For the region outside of the sphere, I'm using Tobias' tutorial (many thanks to him for great tutorials) but with my defined regions not the stl surfaces. ( I also used the stl surfaces, but with no success!)
My problem is snapping not works properly when a finer grid is used as the background mesh by blockMesh, or when I use high levels for refinement region around the sphere. And as a result of bad snapping, layering procedure not works!
My sHM dict is as follows:
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
geometry
sphere
type searchableSphere;
centre (0 0 0);
radius 0.0025;
// Settings for the castellatedMesh generation.
castellatedMeshControls
maxLocalCells 1000000;
maxGlobalCells 2000000;
minRefinementCells 0;
maxLoadUnbalance 0.0;
nCellsBetweenLevels 3;
features
refinementSurfaces
sphere
// Surface-wise min and max refinement level
level (3 3);
resolveFeatureAngle 60;
refinementRegions
locationInMesh (0.01 0.01 0.01);
allowFreeStandingZoneFaces no;
snapControls
nSmoothPatch 3;
tolerance 1.2;
nSolveIter 185;
nRelaxIter 4;
nFeatureSnapIter 5;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
relativeSizes true;
layers
sphere
nSurfaceLayers 6;
// Expansion factor for layer mesh
expansionRatio 1.1;
finalLayerThickness 0.7;
minThickness 0.0001;
nGrow 0;
featureAngle 85;
slipFeatureAngle 25;
nRelaxIter 5;
nSmoothSurfaceNormals 4;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.2;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
meshQualityControls
#include "meshQualityDict"
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
writeFlags
scalarLevels
layerSets
layerFields // write volScalarField for layer coverage
mergeTolerance 1e-6;
And here is blockMeshDict :
convertToMeters 0.0005;
vertices
(-30 -30 -30)
( 30 -30 -30)
( 30 30 -30)
(-30 30 -30)
(-30 -30 30)
( 30 -30 30)
( 30 30 30)
(-30 30 30)
blocks
hex (0 1 2 3 4 5 6 7) (60 60 60) simpleGrading (1 1 1)
edges
boundary
maxY
type wall;
faces
(3 7 6 2)
minX
type wall;
faces
(0 4 7 3)
maxX
type wall;
faces
(2 6 5 1)
minY
type wall;
faces
(1 5 4 0)
minZ
type wall;
faces
(0 3 2 1)
maxZ
type wall;
faces
(4 5 6 7)
mergePatchPairs
For example the whole meshing procedure works well with a 30*30*30 grid and refinement levels of (3 3) around the sphere, but increasing grid numbers to 60*60*60 results bad snapping and no layer around the sphere. while with a 60*60*60 grid and refinement levels of (1 3) around the sphere, everything works well!
I really need to high levels of refinement around the sphere and a finer grid of the whole domain together.
Any help and comment will be appreciated.
Regards,
Arsalan.
