[snappyHexMesh] Could you see my potholes case?
Old   November 28, 2016, 03:25
Default Could you see my potholes case?
W. Lee
postechkian is on a distinguished road
Hello..! I'm beginner of snappyHexMesh.
I'm making some furnace grids with SHM, but it can't make well....
below is my snappyHexMeshDict
and I also attach images about this problem!
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true; // make basic mesh?
snap true; // decide to snap back to surface?
addLayers true; // decide to add viscous layers?
geometry // Load in STL files here
cylinder.stl {type triSurfaceMesh; name cylinder;}
inlet.stl {type triSurfaceMesh; name inlet;}
outlet.stl {type triSurfaceMesh; name outlet;}
body.stl {type triSurfaceMesh; name body;}
bottom.stl {type triSurfaceMesh; name bottom;}
head.stl {type triSurfaceMesh; name head;}
wall.stl {type triSurfaceMesh; name wall;}
//refineHole {type searchableBox; min (5 5 5); max (10 10 10);}
castellatedMeshControls
maxLocalCells 1000000000;
maxGlobalCells 2000000000;
minRefinementCells 10;
nCellsBetweenLevels 3;
maxLoadUnbalance 0.10;
features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
{file "inlet.eMesh"; level 5;}
{file "outlet.eMesh"; level 5;}
{file "body.eMesh"; level 5;}
{file "bottom.eMesh"; level 5;}
{file "head.eMesh"; level 6;}
{file "wall.eMesh"; level 6;}
// Surface based refinement
refinementSurfaces // surface wise min and max refinement level
inlet{level (0 0);}
outlet{level (0 0);}
wall{level (6 6);}
body{level (4 4);}
bottom{level (4 4);}
head{level (6 6);}
resolveFeatureAngle 80; // Resolve sharp angles // Default 30
refinementRegions // In descending levels of fine-ness
{cylinder {mode distance; levels ((0.0006 4) (0.002 3) (0.01 2));}}
locationInMesh (0 2 0); // to decide which side of mesh to keep **
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 5;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 4.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 7;
// Feature snapping
//- Number of feature edge snapping iterations.
// Leave out altogether to disable.
nFeatureSnapIter 15; // defalut is 10
implicitFeatureSnap false; // default is false - detects without doing surfacFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap false; // default is false - detects features between multiple surfaces
// When to run face splitting (never at first iteration, always at last iteration)
// Is interaval. Default -1 (disabled)
// Recommendation : set to half the number of feature snap iterations
nFaceSplitInterval 5;
// Settings for the layer addition.
addLayersControls // add the PATCH names from inside the STL file so STLpatchName_insideSTLName
relativeSizes false;
layers
body {nSurfaceLayers 5;}
head {nSurfaceLayers 5;}
bottom {nSurfaceLayers 5;}
wall {nSurfaceLayers 5;}
expansionRatio 1.3;
finalLayerThickness 0.00048;
minThickness 0.00024;
nGrow 0;
// Advanced settings
featureAngle 80; //- when not to extrude surface. 0 is flat, 90 is right angle.
nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh.
nSmoothSurfaceNormals 1;// Number of smoothing iterations of surface normals
nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction
nSmoothThickness 10; // Smooth layer thickness over surface patches
maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells
maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large
minMedianAxisAngle 130; // Angle used to pick up medial axis points
nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations
nLayerIter 50; // Overall max number of layer addition iterations
// Do not extrude around sharp edge if not both faces are extruded.
// Defalut is 0.5*featureAngle. Set to -180 always attempt extrusion
layerTerminationAngle -180;
// Optional : do not extrude any point where
// (false) : all surrounding faces are not fully extruded
// (true) : all surrounding points are not extruded
// Default is false.
detectExtrusionIsland true;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
#include "meshQualityDict"
// Optional : some meshing phases allow usage of relaxed rules.
// See e.g. addLayersControls::nRelaxedIter.
relaxed
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 75;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Write flags
writeFlags
scalarLevels // write volScalarField with cellLevel for postprocessing
layerSets // write cellSets, faceSets of faces in layer
layerFields // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
postechkian is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 10:13
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
