[snappyHexMesh] Alternating Velocity Field Around Structure
Old   February 28, 2017, 13:09
Default Alternating Velocity Field Around Structure
hulli graemer
hulli is on a distinguished road
Hi all,
I would appreciate it a lot, if you could give me provide me some useful suggestions. I am running a snappyHexMesh case with a stl structure inside. I decided to go with 4 refinement Layers at this stage. After several weeks, and thanks to this forum, I am finally able to generate a mesh that passes the checkMesh. The case I am running is based on the channel 364 tutorial, but I use it with inlet outlet boundary’s, instead of the cyclic ones. However, if I run the case and check the velocity field there are strange alternating velocities becoming visible, which seem to follow the refinement layers (please see pictures). I tried to reduce the time step but it did not really help. So I am kind of lost because I am not sure, if these alternating flow speeds are related again the mesh, or if there is something bad related to the solution. ? Thank you sooo much!!!
hulli is offline   Reply With Quote
Old   May 17, 2017, 07:26
hulli graemer
Any ideas?
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
Determination of the time period for averaging of the velocity field at periodic flow mo92 OpenFOAM Running, Solving & CFD 0 December 18, 2018 12:24
A Question About Setting Whole Velocity Field Using "Proflie" in FLUENT adsl17754 FLUENT 5 July 31, 2018 04:29
Same pressure gradient but different velocity field TurbJet Main CFD Forum 22 April 28, 2018 03:35
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 08:34
