[snappyHexMesh] Creating stl file for snappyHexMesh from xyz coordinates |
April 19, 2017, 14:40 |
Vignesh Rajendiran
Rep Power: 9 |
Hello Guys,
I have to generate a stl file for sHM. I have xyz coordinates for the model. Right now I wrote a code in gmsh to generate a geo file and then convert that into stl file. But that code generates a whole solid stl file. And that has a huge size which is unnecessary for me since it is only used for snapping the profile in sHM and I am going to use the stl file in sHM to do an external flow analysis. A simple thin sheet like extrusion will be enough for my simulation, which will also save a lot of file size. Is there a way to do that? Thanks Vicky |
April 25, 2017, 05:51 |
Kal-El
Rep Power: 9 |
https://sites.google.com/site/snappy...efined-regions
does the searchableBox work for your case? edit: *not a stl, but you can define walls with 'user defined regions' |
April 25, 2017, 08:43 |
Vignesh Rajendiran
Rep Power: 9 |
Hi Kal,
I know the feature that you mentioned. My geometry is complex therefore i need the stl file. Anyway thanks Vicky |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
