June 7, 2017, 00:48 |
how to write swakExpression
harshawardhank
Rep Power: 13 |
Hello Friends
I want to calculate mass transfer coefficient using swak4foam utility formula for MTC is given by " (wallShearStress/U*896)*0.227" value needed at the cell center how to write using swakexpression using function object Last edited by harsha_kulkarni; June 7, 2017 at 06:03. Reason: New error |
June 7, 2017, 06:05 |
harshawardhank
Rep Power: 13 |
MTC
{ type swakExpression; expression "(wallShearStress/U*896)*0.227"; accumulations (sum); valueType cellZone; zoneName faceZone; outputControlMode outputTime; } this is th function object I had used for calculating Mass Transfer Coefficient after that I am getting error [swak4Foam: Setting default mesh [0] [0] [0] --> FOAM FATAL ERROR: [0] The cellZone faceZone was not found in 0() [0] [0] [0] From function getCellZoneID(const fvMesh &mesh,const word &name) [0] in file CellZoneValueExpressionDriver.C at line 63. [0] FOAM parallel run exiting] |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
chtMultiRegionSimpleFoam does not write converged time step | Tobi | OpenFOAM Bugs | 6 | October 14, 2017 11:41 |
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh | elvis | OpenFOAM Community Contributions | 210 | January 30, 2017 18:57 |
Floating point exception (yes...) | sandri_92 | OpenFOAM Running, Solving & CFD | 0 | October 23, 2016 14:42 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
