[Other] Number of faces with non-consecutive shared points |
December 1, 2017, 11:45 |
#1 | |
Canakkale Dardanelspor
Rep Power: 13 |
Suppose, we have an OpenFOAM mesh, and we quantify its mesh metrics through:
checkMesh -allTopology Quote:
Is there any strategy to avoid the warning prior to mesh generation? If not, is there any post-mesh-way to remove it out? PS: The relevant, yet-not-containing-answer threads are as follows: https://www.cfd-online.com/Forums/op...ed-points.html |
checkmesh |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
