May 16, 2018, 11:17 |
edge mesh
Rep Power: 8 |
how can I obtain an object.eMesh file from a stl object? Thank you |
May 17, 2018, 05:15 |
anonymous
Rep Power: 14 |
Hi!
Using the surfaceFeatureExtract utility. In the tutorials/mesh/snappyHexMesh find a tutorial which contains a surfaceFeatureExtractDict in its system directory. Just copy it into your system folder, and rewrite the file names in it. It will generate the .eMesh files into your triSurface folder. Here you can find one. rewrite the motorBike.obj, to yourFile.stl with the includedAngle you can play a bit. https://github.com/OpenFOAM/OpenFOAM...ureExtractDict OR, you can use paraView. Using the feature edges filter on your stl file, and then you can export it. I'm not sure if paraView writes .eMesh file, but i think it can export .obj which is also good for you. |
May 17, 2018, 07:58 |
Rep Power: 8 |
Dear simrego,
i think i'll manage with a surfaceFeatureExtractDict, anyway thank you really much! |
May 17, 2018, 08:05 |
anonymous
Rep Power: 14 |
You're welcome!
If you have multiple STLs, just write them in the dict like this: "Header of the dict file" STL1.stl { "lot of stuff" } STL2.stl { "the same lot of stuff" } etc... |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
