[foamyMesh] foamyHexMesh not installed
Old   March 5, 2018, 10:07
Default foamyHexMesh not installed
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Dear all,
How is it possible that I have foamyHexMexh and the other foamy meshing tool NOT installed with my OpenFOAM 5.0 in Ubuntu 17, but I DO have the tutorials?
Any way of fixing this?
Regards,
C.
aerospain is offline   Reply With Quote
Old   March 15, 2018, 06:32
Paul Palladium
Fauster is on a distinguished road
I have the same problem. The tutorial straightDuctImplicit doesn't work.
F
Fauster is offline   Reply With Quote
Old   March 15, 2018, 07:26
aerospain
F
Thanks for keeping this thread alive Paul. If I find anything new I'll share here
cheers!
C.
Old   April 17, 2018, 06:01
Aaditya Maharashtra
ruikeradity1 is on a distinguished road
I have same problem, when i enter foamyHexMesh it shows: command not found
ruikeradity1 is offline   Reply With Quote
Old   May 15, 2018, 23:53
Ed Barry
ed_bar is on a distinguished road
It's probably not compiled. I find that every time I compile the whole suite of packages, there are some that fail quite often, incl foamyHexMesh. Go into the source and try to compile/recompile foamyHexMesh. You might need to try a few times, checking the error messages and acting accordingly.
ed_bar is offline   Reply With Quote
Old   July 13, 2018, 09:24
Jack B
Jack B is on a distinguished road
I am a beginner (haven't even used foamyHexMesh) but all I know is that the source code for these applications are in the following directory:
$WM_PROJECT_DIR/applications/utilities/mesh/generation
Hope this helps
Jack B is offline   Reply With Quote
[snappyHexMesh] foamyHexMesh boundary layers zordiack OpenFOAM Meshing & Mesh Conversion 14 January 2, 2020 11:55
Issues with poor performance in faster CPU gian93 Hardware 9 October 29, 2018 13:34
[OpenFOAM.org] 4.0: Install without foamyHexMesh Hillie OpenFOAM Installation 4 October 11, 2016 00:41
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
