August 15, 2018, 20:32 |
extrudeMesh does nothing?
Alex
I am trying to create a 2D simulation of a flat plate at various angles against incoming air. I used blockmesh to create a rectangular mesh 1 cell deep (x direction), and then used snappyHexMesh to merge it with the flate plate stl. However this creates more cells in the x direction. I am attempting to use extrudeMesh to make the front face the whole mesh.
When I run extrudeMesh, I get: Code:
Writing mesh to "/mnt/c/Users/Avedis/Desktop/Fluids_stuff/flateplate02D/constant/region0" When I check the constant directory its not there. If I look at the most recent time in paraview, its the same mesh as before. I don't think it did anything. this is my extrudeMeshDict: Code:
constructFrom patch; sourceCase "."; sourcePatches (front); exposedPatchName back; flipNormals false; extrudeModel linearNormal; nLayers 1; expansionRatio 1.0; linearNormalCoeffs { thickness 0.01; } mergeFaces false; |
September 13, 2018, 06:00 |
matej forman
Rep Power: 17 |
Hi, not sure if it is still an issue, but perhaps there was some message utility prints out to the terminal? What does it say?
June 2, 2021, 03:17 |
Léo BAZIN
Rep Power: 5 |
Hello, this topic may be a bit old, but I'm currently working on OpenFoam and also trying to get a 2D mesh after snappyHexMesh turned my 2D mesh into a 3D mesh. So I used extrudeMesh as Chubmaster did and got the same issue. My mesh is apparently written in constant/region0 but there is no region0 file in my constant folder. Does anyone managed to use extrudeMesh and get a 2D mesh ?
June 2, 2021, 03:33 |
matej forman
Rep Power: 17 |
the information that your mesh was written to constant/region0 maybe is not very lucky one, but is here for the cases you build multiregion mesh. Region0 is the default one, so your mesh is written to constant/polyMesh/ directory. In case of a multiregion mesh, it would be constant/<regionName>/polyMesh. If you have more doubts, try >> find $FOAM_TUTORIALS -name extrudeMeshDict for more examples. Hope it helps |
June 2, 2021, 05:39 |
Léo BAZIN
Rep Power: 5 |
Thank you for your answer. I tried to run some tutorials which uses this and I finally found what was wrong. It is necessary to execute "snappyHexMesh -overwrite" instead of just "snappyHexMesh" before running extrudeMesh. I hope this can help people. |
June 2, 2021, 08:28 |
matej forman
Rep Power: 17 |
Yes. Well done. SnappyHexMesh is writing the mesh to the time directory according to the time step settings in <system>/controlDict. So without an argument, it is going to write the mesh into a next time directory. overwrite option will make it to write the polyMesh directory into a constant directory.
You can actually copy the polyMesh directory manually yourself e.g.: >> cp -r 3/polyMesh constant/polyMesh if your snappyHexMesh has written the final mesh to time dir. 3. For more info on snappyHexMesh, please look here: https://www.openfoam.com/documentati...pyhexmesh.html happy foaming |
extrudemesh, snappyhexmesh |
[mesh manipulation] extrudeMesh can't find any patches | shang2 | OpenFOAM Meshing & Mesh Conversion | 6 | February 26, 2021 20:46 |
[mesh manipulation] extrudeMesh limits Adaptive/Dynamic Mesh Refinenemt | potentialFoam | OpenFOAM Meshing & Mesh Conversion | 3 | January 29, 2018 03:42 |
[mesh manipulation] Generating 3-D axisymmetric mesh using extrudeMesh | martyn88 | OpenFOAM Meshing & Mesh Conversion | 17 | June 21, 2017 19:42 |
[snappyHexMesh] Problem with extrudeMesh sHM 2D airfoil mesh | ssss | OpenFOAM Meshing & Mesh Conversion | 2 | September 1, 2014 13:12 |
[snappyHexMesh] snappyHexMesh after extrudeMesh / Creating background mesh with extrudeMesh | pythag0ra5 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2013 09:10 |
