[surface handling] surfaceFeatureExtract error |
December 7, 2018, 07:32 |
ssa
Rep Power: 7 |
I created an stl file and try to run surfaceFeature Extract and It says the stl file is not closed. Code:
Create time Reading surfaceFeatureExtractDict Surface : "propellor.stl" Feature line extraction is only valid on closed manifold surfaces. --> FOAM FATAL ERROR: Cannnot read "/home/student/Desktop/propellor/constant/triSurface/propellor.stl" From function bool Foam::triSurface::read(const Foam::fileName&, const Foam::word&, bool) in file triSurface/triSurface.C at line 360. FOAM exiting Then I ran surfaceCheck. which says the surface is closed. Code:
Reading surface from "propellor.stl" ... Statistics: Triangles : 270454 Vertices : 135229 Bounding Box : (-0.00728054 -0.501997 -0.37755) (0.166692 0.493293 0.5542) Region Size ------ ---- propellor 270454 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0.0417668 0.05 .. 0.1 : 0.0239153 0.1 .. 0.15 : 0.0266663 0.15 .. 0.2 : 0.0238266 0.2 .. 0.25 : 0.0227839 0.25 .. 0.3 : 0.0227358 0.3 .. 0.35 : 0.0232646 0.35 .. 0.4 : 0.0276535 0.4 .. 0.45 : 0.0273207 0.45 .. 0.5 : 0.0324676 0.5 .. 0.55 : 0.0323974 0.55 .. 0.6 : 0.0405577 0.6 .. 0.65 : 0.0527964 0.65 .. 0.7 : 0.0692576 0.7 .. 0.75 : 0.135202 0.75 .. 0.8 : 0.397365 0.8 .. 0.85 : 0 0.85 .. 0.9 : 1.10925e-05 0.9 .. 0.95 : 0 0.95 .. 1 : 1.10925e-05 min 3.3659e-09 for triangle 5843 max 0.996196 for triangle 10681 Edges: min 7.53845e-06 for edge 72478 points (0.0670674 0.000787644 -0.0999962)(0.0670606 0.000790893 -0.0999962) max 0.336725 for edge 8762 points (0.00104856 -0.0940534 0.498164)(0.0519718 0.194747 0.332681) Checking for points less than 1e-6 of bounding box ((0.173973 0.99529 0.93175) metre) apart. Found 0 nearby points. Surface is closed. All edges connected to two faces. Number of unconnected parts : 1 Number of zones (connected area with consistent normal) : 1 End Thanks, ssa |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
