[snappyHexMesh] snappyHexMesh refinement
Like Tree1Likes
  • 1 Post By Axel_T
Old   December 11, 2009, 03:44
Default snappyHexMesh refinement
Vincent RIVOLA
vinz is on a distinguished road
Dear snappyHexMesh users,
I've been playing with snappy for a few days and I am wondering something. Is it beter to start snappy with a very fine mesh as a base ans only do 1 or 2 level of refinement around my surface, or to start with a coarse mesh and then impose 6or 8 level of refinement in the snappyHexMeshDict?
To give an example, let say we have a mesh at level 1 in blockMesh, the two options are:
- use this mesh and chose a uniform refinement of 4 around the surface in snappy.
- refine blockMesh mesh by 4 in each direction and then use snappy without refinement, or with a refinement level of 1.
Not easy to explain, but i hope you'll understand.
If somebody have an idea, that would be nice.
Regards,
Vincent
vinz is offline   Reply With Quote
Old   December 19, 2009, 14:13
Default refinement ratio
Axel Tietjen
Axel_T is on a distinguished road
Hi Vincent,
the only important thing is the maximum and minimum size of our cells.
When you want to set a refinement with a ratio of 1:8 towards the surface, and the cell size at the surface schould be, lets say 2mm, the initial cell size would be 16mm and the surfaceRefinement-level in sappy would be then 3. (2³=8)
Since very small cells make your solution slower and more unstable, and a too coarse mesh delivers not enough information, this is a important point to think about.
If you are starting with a very coarse mesh from blockMesh, snappy would need perhaps more time for the refinement iterations. But I'm not shure - perhaps you could do some experiments and post the results here.
windiman likes this.
Axel_T is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
