[snappyHexMesh] Problems meshing a pipe
Old   November 16, 2010, 06:19
Default Problems meshing a pipe
Ulrich Golling
U.Golling is on a distinguished road
Dear Foamers,
I want to mesh a pipe-system with snappyHexMesh. The best way to do it seems to be: 3 stl-Files one for the pipe, one for the inlet and one for outlet. Right?
But i don't get it right. Can you tell me, how the geometries behind this stl-Files have to look like? Can i define just areas for Inlet and Outlet and the wall of the pipe (my CAD-programm (Inventor Prof.2011) says: no, a geometry has to be a volume-body to export it as *.stl)?
I am still a beginner in OpenFoam and so thankfull for every help and hint you can give, concerning simulating internal flow problems.
greets
U.
U.Golling is offline   Reply With Quote
Old   November 23, 2010, 00:12
Paul Reichl
preichl is on a distinguished road
Hi Ulrich,
Specifying 3 stl files is how I have looked at similar problems in the past. I normally export my geometries from SolidWorks and I am able to export stl files for both the entire 3D geometry and for selected surfaces.
In SolidWorks I can select a surface from the 3D part and then select save as an STL file and it will ask if I want to save just the surface or everything. Selecting just the surface is what I choose to get an stl file for each boundary.
I am not familiar with Inventor Prof 2011, but have you tried doing something similar?
The basic format of an STL files is discussed at http://en.wikipedia.org/wiki/STL_(file_format)
I hope this helps somewhat.
Cheers,
Paul.
preichl is offline   Reply With Quote
Old   November 30, 2010, 05:24
Ulrich Golling
Hello Paul,
thank you for your help. As far as i know, until now, Inventor cannot export just a surface in a stl-File. But it is not a problem anymore, for me.
In the end my biggest mistake in this case was something other: Open Foam is in meter and my inventor-stl-file was in mm. A slight mistake.
Thanks and
greets
U
flow, intern, internal, mesh, pipe
[snappyHexMesh] Problems with scaling meshes when meshing with SnappyHexmesh Bnitter OpenFOAM Meshing & Mesh Conversion 1 November 15, 2018 08:26
[ANSYS Meshing] Problems with connections/contacts while meshing in Ansys: cfd_worker99 ANSYS Meshing & Geometry 0 August 22, 2017 16:25
[ICEM] Problems with meshing a 3D wing w/winglet cesarcg ANSYS Meshing & Geometry 10 March 18, 2013 12:12
[ICEM] ICEM PIPE bend meshing firavia ANSYS Meshing & Geometry 3 December 23, 2012 09:29
Problems with Cyclic & init. BCs for turbulent (k-eps) pipe flow florian_krause OpenFOAM 3 December 1, 2012 04:11
