[snappyHexMesh] How to create a separate patch on a blockmesh surface
Old   April 24, 2011, 11:35
Default How to create a separate patch on a blockmesh surface
Bing Guo
bing.guo is on a distinguished road
Hello Everyone,
I want to simulate the flow around/through an air sampling apparatus. The idea is to use a block domain; wind flows in from the left side of the block, passes the apparatus and leaves from the right side of the block. Also, a stream of air enters the apparatus, flows down a tube, and leaves from the exit of the tube at the bottom of the block. Top, side and bottom surfaces of the block have slip boundary conditions. The tube exit should be a separate patch on the bottom surface of the block, having an outlet boundary condition.
I ran blockMesh and then ran snappyHexMesh with the stl surface of the apparatus partially enclosed in the block (end of the tube sticking out of the bottom of the block).
The problem is that snappyHexMesh did not create a separate patch for the tube exit on the bottom of the block. Is that even possible with the "standard" applications available in OpenFOAM? In addition, what are the typical boundary conditions for two outlets (flow split ratio is known between the two outlets)? Any insight will be greatly appreciated. Thanks.
File Type: jpg Block air sampling device section view.jpg (27.6 KB, 22 views)
bing.guo is offline   Reply With Quote
separate patch, snappyhexmesh, two outlets
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
