[Technical] Order of vertices
Like Tree1Likes
  • 1 Post By Nikunj.R
Old   July 9, 2012, 14:42
Default Order of vertices
Nikunj Raithatha
Nikunj.R is on a distinguished road
Hello!
Section 5.3 of user manual shows a way to order the vertices while defining a block. Does this order have to be followed while defining the vertices in the blockMeshDict file? If it is so, then how do i define a block whose cross section is, saya a pentagon or concentric circle (for defining a hollow cylinder)?
Thanks,
Nikunj.
Gwind likes this.
Nikunj.R is offline   Reply With Quote
Old   March 5, 2014, 05:59
cutter is on a distinguished road
the order of the vertices within your model is completely irrelevant.
Just split your model into blocks and list the vertices of the model in an order of your choice. But make sure that the topology of each block matches the picture on http://www.openfoam.org/docs/user/blockMesh.php . blockMesh will do the rest.
The hollow cylinder can be done using two half cylinders for example.
Cutter
cutter is offline   Reply With Quote
How grid resolution for a wave number depends on the scheme order? marinkobezu Main CFD Forum 9 September 21, 2017 13:11
upwind finite volume order of accuracy less than one ?? dgfem Main CFD Forum 7 June 1, 2015 05:02
1st or 2nd order gradients approach? fireflies Main CFD Forum 2 September 18, 2014 09:07
Unstable flow simpleFoam 2nd order Valle OpenFOAM 0 August 26, 2009 09:12
1st order temporal & 2nd order spatial Prateep Chatterjee FLUENT 0 January 19, 2003 01:31
