Home > Forums > OpenFOAM Meshing Format & General Technical
Problems with mesh processing
Old   November 22, 2015, 23:30
Default Problems with mesh processing
Saurabh Tandon
STutexas is on a distinguished road
Hi
I am new user in OpenFOAM and I am trying to export a 3D mesh to openfoam. I am been successful in exporting the mesh but the when I run checkmesh I get the following error:
***Boundary openness (-0.00577288 -0.0138324 -0.0075081) possible hole in boundary description.
***Open cells found, max cell openness: 1, number of open cells 794
<<Writing 794 non closed cells to set nonClosedCells
<<Writing 704 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 0.338918. Maximum face area = 26.1411. Face area magnitudes OK.
***Zero or negative cell volume detected. Minimum negative volume: -39.3144, Number of negative volume cells: 621
<<Writing 621 zero volume cells to set zeroVolumeCells
Mesh non-orthogonality Max: 179.417 average: 89.7196
*Number of severely non-orthogonal (> 70 degrees) faces: 139.
***Number of non-orthogonality errors: 991.
<<Writing 1130 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 2453 faces are incorrectly oriented.
<<Writing 1602 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 96.5521, 34 highly skew faces detected which may impair the quality of the results
<<Writing 34 skew faces to set skewFaces
Is is possible for someone to explain these errors. I know very little about meshing or the mathematics of the process. More importantly is it possible to rectify the errors in OpenFOAM or would I have to mesh again?
STutexas is offline   Reply With Quote
Old   November 23, 2015, 07:55
cutter is on a distinguished road
This seems to be a very bad mesh that probably won't run. Most likely something went wrong during export. You really need to provide more infos in order to get back useful hints!
Did you read https://openfoamwiki.net/index.php/CheckMesh? Have you tried to visualize the mesh using paraview or paraFoam?
cutter is offline   Reply With Quote
Old   November 26, 2015, 02:06
Saurabh Tandon
Hi
Thank you replying to my post. Here is the context of my research. I am trying to use OpenFOAM to do pore scale simulations in rocks for magnetization decay. An example of the geoemtry that I am meshing be seen in this link
https://www.spec2000.net/09-corebasics.htm.
I would like to mesh disconnected geometry and I am not getting good results with cgal or gmsh. I am open to any feedback that you might have about meshing, I have studied the link that you posted below. Thanks again for the help.
Old   November 26, 2015, 02:12
Saurabh Tandon
This is my gmsh file. Please chnage the name of the file to gmsh file and run it on s software that can process gmsh files.
Thread Tools
Trackbacks are On
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 30 Today 13:25
Problems with mesh processing STutexas OpenFOAM Meshing & Mesh Conversion 3 November 23, 2015 01:56
mesh causing problems with convergence Tetragramm OpenFOAM Native Meshers: blockMesh 0 September 22, 2012 16:00
problems about mesh size and post processing cuteapathy FLUENT 1 July 3, 2012 16:41
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
