[cfMesh] Refinement diffusion or in snappy-variables: nCellsBetweenLevels
Old   April 12, 2019, 04:40
Default Refinement diffusion or in snappy-variables: nCellsBetweenLevels
Gerd Fade
schiffbauer is on a distinguished road
Dear Foamers,
cfMesh has a lot advantages over snappy, but one point seems to be a problem:
How can I increase the number of cells between levels? In snappy, the variable is: nCellsBetweenLevels.
Usually cfMesh puts only one or two cells between different refinement levels which leads to a bad mesh quality and to solver issues i.e. with DES-approaches.
schiffbauer is offline   Reply With Quote
Old   April 15, 2019, 05:41
Thomas Sprich
Swift is on a distinguished road
Hi Gerd,
I couldn't find an obvious solution like snappyHexMesh would use.
Could you play with the other refinement options, such as refinementThickness and cellSize options to get the mesh size distribution that you want?
For example if you have two mesh areas with two mesh sizes, could you create a refinement area between those zones and specify an intermediate cell size. This should help get a better cell size distribution which may resolve the quality issues.
Its a bit of a workaround, but may help.
Regards,
Thomas
Swift is offline   Reply With Quote
Old   February 16, 2020, 17:37
benoit paillard
bennn is on a distinguished road
Hi all,
I also think that is a neat feature of Snappy, and a good way to get quality meshes. I think it would be a great addition to cfmesh !
bennn is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
Diffusion of Additional variables in solid october ANSYS 5 September 9, 2014 03:58
turbulent diffusion term in transport equation for additional variables Raijin Thunderkeg CFX 2 May 17, 2014 22:53
[snappyHexMesh] nCellsBetweenLevels Eloise OpenFOAM Meshing & Mesh Conversion 0 November 16, 2013 11:09
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
