[Technical] 2D foam mesh and internal points
Old   March 23, 2009, 10:45
Default 2D foam mesh and internal points
Virginie Ehrlacher
virginie_e is on a distinguished road
I have imported a 2D mesh from Fluent into OpenFoam and everything ran fine: the 2D mesh was transformed in a 3D mesh by extruding one cell in the 3rd direction.
My question is: in this case, are there any internal points? Are the points of the empty patches considered as internal points or not? Are all the points boundary points?
Thank you for your help
Virginie
virginie_e is offline   Reply With Quote
Old   March 31, 2009, 16:24
Sandeep Menon
deepsterblue will become famous soon enough
Yup. They're all boundary points. Empty patches and all.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   April 1, 2009, 03:25
Virginie Ehrlacher
Thank you Sandeep
Old   February 28, 2014, 00:05
Zhenquan Li
jali is on a distinguished road
Hi guys,
I run blockMesh for cavity flow copied from OpenFOAM tutorials and checked generated points, faces and boundary files. I found that some of the faces in the faces file are not real faces, e.g., 4(21 462 463 22). Can you check please? Do you guys know the relations among neighbour, owner, points, faces, and boundary files? I know points file lists all points in the mesh, faces file contains all faces described by the points in points file, boundary file gives the type of boundaries and the number of faces and the number of the start face for each type in the faces file. How about owner and neighbour files? Thanks a lot.
jali is offline   Reply With Quote
openfoam mesh files
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
