[blockMesh] BlockMesh creates wedge cells instead of hexahedron
Like Tree3Likes
  • 1 Post By sweet_satan
  • 1 Post By zfaraday
Old   November 20, 2014, 07:59
Default BlockMesh creates wedge cells instead of hexahedron
sweet_satan is on a distinguished road
Hello everyone,
I have a problem because blockMesh creates wedge cells instead of hexahedron, you can see that on attached picture.
The geometry consist of few blocks and each is splitted to four smaller blocks (so I could use mesh grading in direction to the wall). I have attached my blockMeshDict.
The problem is with the last part of geometry - 4 last blocks - lines 133 to 136 in blockMeshDict. Before that part I have an elbow. When I create mesh with elbow I get what you can see on the attached picture. When I comment out elbow blocks in blockmeshDict I get normal hexahedron cells.
I have no idea where the error is. Can anyone help?
vatavuk likes this.
sweet_satan is offline   Reply With Quote
Old   November 20, 2014, 08:41
Alex
zfaraday will become famous soon enough
May it be a visualization problem of paraview? Have you checked your mesh with checkMesh utility?
sweet_satan likes this.
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   November 20, 2014, 08:55
CheckMesh says there are only hexahedra cells, so you are right. Thank you very much for your post.
zfaraday likes this.
Old   November 21, 2014, 05:59
Paulo Vatavuk
vatavuk is on a distinguished road
Hi sweet_satan,
Could you tell us what version of Paraview you are using?
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   November 23, 2014, 16:04
I am using ParaView 4.1.0 64-bit. I have found that I made a mistake in that last part and corrected it, so it turns out it wasn't visualization error. I am attaching current blockMeshDict in case anyone is interested.
I still get 1 failed check with checkMesh, but now at least it looks beautiful .
[snappyHexMesh] Snappy creates strange cells far away from boundary vainilreb OpenFOAM Meshing & Mesh Conversion 3 December 16, 2020 05:11
[blockMesh] Sphere mesh with blockMesh - weird cells TheMadHungarian OpenFOAM Meshing & Mesh Conversion 1 October 22, 2018 09:03
[snappyHexMesh] Avoiding wedge cells and folded cells while adding layers - snappyHexMesh Saideep OpenFOAM Meshing & Mesh Conversion 2 March 22, 2018 08:10
[blockMesh] blockMesh problem with wedge blocks gned OpenFOAM Meshing & Mesh Conversion 0 September 14, 2016 05:49
wedge cells pridicting high T-KE why? shan Siemens 0 September 21, 2006 14:12
