[blockMesh] Wedge shape in blockMesh process
Old   March 5, 2013, 11:51
Default Wedge shape in blockMesh process
Arthur Piquet
halowine is on a distinguished road
hi,
Screenshot from 2013-03-05 11:43:25.jpg
I'm trying to make a wedge shape on a simple case for OpenFoam (see above).
I made this blockmesh file :
blockMeshDict (copy).txt
And like you see in the picture above, there is a problem with the prism block from a hex block. Every mesh line pointing the collapse vertice.
What I want is that the mesh become straight. Anyone know how to do that?
Thx
halowine is offline   Reply With Quote
Old   March 5, 2013, 20:41
yu
xiyuqiu is on a distinguished road
Hi I would lower the mesh density first. Make it 3 or something for each direction. That way it is easier to see. My experience with this type of the problem is one or more of your vortex had the wrong coordinates.
xiyuqiu is offline   Reply With Quote
Old   April 11, 2013, 04:07
Yosmcer Mocktai
Yosmcer will become famous soon enough
Maybe you could try to put the collapse vertices in 2-10 (instead of 1-9). That would make the line converging this point, so the perpendiculars lines would be parallel to the 1-7 (and 9-15) line. Or maybe you could be more explicit about the "straight lines" you want?
Yosmcer is offline   Reply With Quote
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
shape optimization problem yugang881 SU2 Shape Design 3 December 14, 2017 05:26
[SOLVED] sprayFoam - Hitting a wedge patch should not be possible Malikos OpenFOAM Running, Solving & CFD 1 March 10, 2016 12:03
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 17:08
Wall boundary is ignored when using wedge Wedge OpenFOAM 1 February 7, 2011 06:20
