[snappyHexMesh] orthogonality problem with raw STL file
Old   April 15, 2013, 11:53
Default orthogonality problem with raw STL file
Debb
tellico is on a distinguished road
I've been trying to use snappy on an (ascii) stl file that was created by scanning a hallway.
After running snappyHexMesh I get a lot of orthogonality issues, and I'm unable to run simpleFoam on the generated mesh.
I'm pretty sure the issue is with the raw stl file, but I'm not sure what the stl criteria should be.
Any advice on what I can do to the raw stl data to avoid these issues?
I've attached a screen shot of the raw stl data in paraView.
tellico is offline   Reply With Quote
Old   April 16, 2013, 03:18
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Have you run the surfaceCheck utility on the file? What does that report?
Visually where is the mesh bad? You can subset the bad cells and faces to view in paraview.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
