[blockMesh] keep getting errors from blockMesh saying: "negative volume" |
November 9, 2014, 08:34 |
Rep Power: 11 |
Hi everyone,
I am very new to OpenFOAM and after much pain and struggle, I finally installed OF 2.3.0 on VMware player with Ubuntu 14.04 32bit. Eventually, I want to implement an actuator disc model and do some flow analysis. I tried googling and got some info but it is just overwhelming for me - going no where. This is a noob question - but is there any CAD software that can automatically generate this blockMeshDict file? So, right now, I am learning how to use blockMesh and create some simple mesh according to this tutorial I found online : http://www.fm.energy.lth.se/fileadmi...rExercise1.pdf My blockMeshDict code Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (3 0 0) (3 1 0) (0 1 0) (4 2 0) (5 2 0) (4 5 0) (5 5 0) (0 0 0.1) (3 0 0.1) (3 1 0.1) (0 1 0.1) (4 2 0.1) (5 2 0.1) (4 5 0.1) (5 5 0.1) ); blocks ( hex (0 1 2 3 8 9 10 11) (40 10 1) simpleGrading (1 1 1) // block 0 hex (1 5 3 4 9 13 11 12) (40 10 1) simpleGrading (1 1 1) // block 1 hex (4 5 6 7 12 13 14 15) (10 40 1) simpleGrading (1 1 1) // block 2 ); edges ( arc 3 4 (1.2 3.6 0.0) // arc through vertices 3 and 4, through a point arc 1 5 (4.0 0.2679 0.0) // arc through vertices 1 and 5, through a point arc 11 12 (1.2 3.6 0.1) // arc through vertices 11 and 12, through a point arc 9 13 (4.0 0.2679 0.1) // arc through vertices 9 and 13, through a point ); boundary // any boundary patch omitted is assigned a type empty ( inlet // given name of patch (i.e. region) { type patch; faces ( (8 10 2 0) // vertices that define the patch, clockwise from inside block ); } outlet { type patch; faces ( (6 14 15 7) ); } blockzerooutlet { type patch; faces ( (1 3 11 9) ); } blockoneinlet { type patch; faces ( (9 11 3 1) ); } blockoneoutlet { type patch; faces ( (4 12 13 5) ); } blocktwoinlet { type patch; faces ( (5 13 12 4) ); } frontAndBack // 2D problem x-y { type empty; faces ( (0 2 3 1) (3 4 5 1) (4 6 7 5) (9 11 10 8) (13 12 11 9) (13 15 14 12) ); } topAndbottomWalls { type wall; faces ( (2 10 11 3) (1 9 8 0) (3 11 12 4) (5 13 9 1) (4 12 14 6) (7 15 13 5) ); } ); mergePatchPairs ( (blockzerooutlet blockoneinlet) (blockoneoulet blocktwoinlet) ); // ************************************************************************* // Any help is really very much appreciated! Thank you! |
November 9, 2014, 08:52 |
#2 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings hwsv07 and welcome to the forum!
If you visit that thread, it will point you to a wiki page, in which you'll find a section entitled "Graphical User Interfaces for visualizing and designing blockMeshDict": http://openfoamwiki.net/index.php/Bl..._blockMeshDict Quote:
Best regards, Bruno
November 9, 2014, 13:22 |
Rep Power: 11 |
Hi wyldckat,
I took your advice and broke up my mesh into separate blocks and found out my problem. I mis-read how I should number my vertices. so now I have to managed to generate my 3 blocks. However, I still have a problem. I have specified a curve edge, but when I previewed my mesh in paraview, it does not show me the curve edge. Is there something I did wrong? How I did to preview mesh was as follows: Code:
blockMesh -blockTopology I then opened paraview. blockCentres.obj does not show me anything, but blockTopology.obj only shows me the outline, but I cannot see the mesh though (I selected Wireframe under Properties - I tried some tutorials, and I know using WireFrame allows me to see the mesh grids). Am I doing something wrong here? I also tried to preview mesh by just running Code:
blockMesh paraFoam Code:
user@ubuntu:~/Desktop/Link to MySimulation/pipe$ paraFoam created temporary 'pipe.OpenFOAM' fileName::stripInvalid() called for invalid fileName /home/user/Desktop/LinktoMySimulation/pipe/pipe.OpenFOAM For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) Below is my blockMeshDict. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) // block 0 (0 to 7) (3 0 0) (3 1 0) (0 1 0) (0 0 1) (3 0 1) (3 1 1) (0 1 1) (4 2 0) // block 2 (8 to 15) (5 2 0) (5 5 0) (4 5 0) (4 2 1) (5 2 1) (5 5 1) (4 5 1) (3 0 0) // block 1 (16 to 23) (5 2 0) (4 2 0) (3 1 0) (3 0 1) (5 2 1) (4 2 1) (3 1 1) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) // block 0 // hex (16 17 18 19 20 21 22 23) (20 20 1) simpleGrading (1 1 1) // block 1 hex (1 9 8 2 5 13 12 6) (20 20 1) simpleGrading (1 1 1) // block 1 hex (8 9 10 11 12 13 14 15) (20 20 1) simpleGrading (1 1 1) // block 2 ); edges ( /* arc 19 18 (3.6 8 0) arc 16 17 (4.0 0.2679 0) arc 23 22 (3.6 1.2 1) arc 20 21 (4.0 0.2679 1) */ arc 2 8 (3.6 8 0) arc 1 9 (4.0 0.2679 0) arc 6 12 (3.6 1.2 1) arc 5 13 (4.0 0.2679 1) ); boundary // any boundary patch omitted is assigned a type empty ( inlet // given name of patch (i.e. region) { type patch; faces ( (4 7 3 0) // vertices that define the patch, clockwise from inside block ); } outlet { type patch; faces ( (11 15 14 10) ); } /* block0outlet { type patch; faces ( (2 6 5 1) ); } block1inlet { type patch; faces ( (16 20 23 19) ); } block1outlet { type patch; faces ( // (18 22 21 17) (8 12 13 9) ); } block2inlet { type patch; faces ( (9 13 12 8) ); } */ topAndbottomWalls { type wall; faces ( (3 7 6 2) // block 0 (1 5 4 0) (8 12 15 11) // block 2 (10 14 13 9) // (19 23 22 18) // block 1 // (17 21 20 16) (6 12 8 2) // block 1 (1 9 13 5) ); } ); mergePatchPairs ( /* (block0outlet block1inlet) (block1outlet block2inlet) */ ); // ************************************************************************* // |
November 9, 2014, 13:27 |
Bruno Santos
Rep Power: 128 |
Quick answer:
November 9, 2014, 14:40 |
#5 | |
Rep Power: 11 |
Display Modes | |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 25 | December 2, 2021 10:40 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 04:41 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
