Multiple overlapping meshes
I'm trying to create a mesh which consists of a global mesh and some smaller meshes. So lets say I have the global mesh (via blockMesh created) M and this mesh is divided into smaller meshes A,B,C,D via splitMeshRegions after creating cellSets and cellZones with setsToZones. Now I have the global mesh M and the smaller meshes A,B,C,D where different equations are solved and mapped between those meshes. Now I want to create another small mesh E which contains the regions of mesh B and C to solve an other type of equation there. If I want to create such a mesh using cellSets/cellZones and splitMeshRegions (containing the regions of B and C) I get the error: Code:
--> FOAM FATAL ERROR: Thanks in advance for your help! |
have u soleved your problem?
Have you found the solutions for " want to create another small mesh E which contains the regions of mesh B and C to solve an other type of equation there. "? I am facing a same problem. Hope get suggestion from you. Jiatang |
