April 12, 2017, 10:51 |
dynamicRefineFvMesh with simpleFoam crash
Jeroen
Rep Power: 9 |
For the purpose of my solver, I want to refine the mesh at a certain edge, that is found by my topology optimization. This can be seen in the attached figure. After some research, dynamicRefineFvMesh seems to be the 'go to' class. I've implemented the mesh.update() command in my simplFoam loop, similar to the pimpleDyMFoam implementation: Code:
fvc::makeAbsolute(phi, U); Info<< "Time = " << runTime.timeName() << nl << endl; magAlphaGrad = mag(fvc::grad(alpha)); counter += 1; if(counter>activateVolume) { mesh.update(); } Code:
Time = 2 Selected 468 cells for refinement out of 120000. Refined from 120000 to 123276 cells. Selected 0 split points out of a possible 468. We're sorry, but the application crashed and safe stack tracing isn't available in this current implementation of blueCFD-Core patches for OpenFOAM. Any ideas where I should look, regarding this crash? |
December 31, 2017, 13:23 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings verboomj,
I'm really late to give an answer to you on this, but I do have two suggestions for you:
Bruno
February 12, 2020, 13:16 |
#3 | |
Rep Power: 6 |
I am new in topology optimization of fluid and thermal by using OpenFOAM, could you please share any basic codes or tutorials of this? It would better for me to start to replicate some cases. Thank you so much. regards |
simpleFoam crash fast! | izna | OpenFOAM Running, Solving & CFD | 28 | February 3, 2017 13:24 |
SimpleFoam crash at first loop | alvariten | OpenFOAM Running, Solving & CFD | 5 | August 17, 2015 07:17 |
Simulation crash with dynamicRefineFvMesh and kOmegaSST - OF 2.3.x | nathanael | OpenFOAM Running, Solving & CFD | 4 | June 29, 2014 17:02 |
[blockMesh] Grading leads to simpleFoam crash | yanyanh | OpenFOAM Meshing & Mesh Conversion | 3 | March 2, 2014 11:08 |
simpleFoam crash -> How to solve | tH3f0rC3 | OpenFOAM | 4 | May 12, 2011 07:07 |
